I have a boron pulling serial data from a solar charge controller and publishing those values using Particle.publish(). I want to replicate Campbell Scientific datalogger behavior with the boron. With CSci, the main loop scans with the system clock and tables are written/aggregated with the clock as well. For example, scans set to every 3 seconds and tables written every 1 minute would result in values taken at 12:00:03, 12:00:06, 12:00:09, etc. with the table written at 12:01:00, 12:02:00 etc.
Here’s a basic working example of how I’m implementing this currently:
#include <math.h>
#include "Statistic.h"
const unsigned long scanInterval = 10000; // 10 seconds
const unsigned long publishInterval = 3000000; // 5 minutes
long int timestamp;
unsigned long previous_scan_millis = millis();
uint8_t pollmessage[6] = {0xAA, 0x55, 0x00, 0x00, 0x00, 0x55};
byte rawdata[20];
Statistic Stats[1];
SYSTEM_THREAD(ENABLED);
Serial1.begin(9600);
if (millis() - previous_scan_millis >= scanInterval && (Time.now() % (scanInterval/1000) == 0)) {
timestamp = Time.now();
Serial1.write(pollmessage, sizeof(pollmessage));
//300ms delay as device responds
Serial1.readBytes((char *)rawdata, 20);
Stats[0].add((rawdata[3] << 8 | rawdata[2])/10.0);
//Publish
if (timestamp % (publishInterval/1000) == 0) {
Particle.publish("battvolts",String::format("%.2f",Stats[0].average()));
Stats[0].clear();
This generally works okay, but I have a few missed publishes per day. I’m not 100% sure if it’s because of my time logic (please let me know if there’s a better way to do this) or because of a blocking issue with Particle.publish() and cell connectivity. What are some good tips for doing this kind of behavior and avoiding skipped Publishes?
Thanks for the help!
