Hi, I can subscribe to my event in Node-Red Particle-SSE node, the data comes through fine except the data field is sent as a string.
Example:
{"data":"{ \"temp\": 22.00, \"voltage\": 4.05 }","ttl":60,"published_at":"2020-07-06T13:45:09.157Z","coreid":"xxxxxxxxxxxxxxxxxxxxxxx","name":"osVoltage"}
See how the data is a string;
It means I need to do some extra parsing to split that out. Does anyone know why it’s doing that?
Alex
When you encode JSON and send it from a function, it will always be escaped, as you see here. This allows sending data that includes special JSON characters (ie if you wanted to send data that included " characters), and is a security feature.
It is a simple matter of decoding the string into a JSON object in your endpoint (ie JSON.parse() in javascript)
Hi, is not easy also i’m not familiar with Node-Red
(but is pretty much js).
I was able to parse your data field strings in pure js maybe this can help or give you some light.
<!DOCTYPE html>
<html>
<body>
<h2>convert JSON value String to JSON</h2>
<script>
var txt = '{"data":"{"\temp\": 22.00, "\voltage\": 4.05 }","ttl":60,"published_at":"2020-07-06T13:45:09.157Z","coreid":"xxxxxxxxxxxxxxxxxxxxxxx","name":"osVoltage"}';
String.prototype.removeCharAt = function (i) {
var tmp = this.split(''); // convert to an array
tmp.splice(i - 1 , 1); // remove 1 element from the array (adjusting for non-zero-indexed counts)
return tmp.join(''); // reconstruct the string
var obj1 = JSON.stringify(txt); // convert to string
var obj2 = obj1.replace(/\\/g, ''); // remove all backslash
var obj3 = obj2.replace("u000b", "v"); // for some reason after removing backshlashes "v" is changing to "u000b" so replaced back to "v"
var obj4 = obj3.slice(1, obj3.length - 1); // remove " " " which is on first and last position
var obj5 = obj4.removeCharAt(9); // remove " " " on pos 9
var obj6 = obj5.removeCharAt(42); // remove " " " on pos 42
var finall = JSON.parse(obj6);
console.log("step 1 obj1",obj1);
console.log("step 2 obj2",obj2);
console.log("step 3 obj3",obj3);
console.log("step 4 obj4",obj4);
console.log("step 5 obj5",obj5);
console.log("fliall", finall);
console.log("temp value from Data", finall.data.temp);
</script>
</body>
</html>
removeCharAt function is from here also you don’t need var obj1,obj2,obj3…etc as you can do this “on-flight”
This is just to show the conversion idea step by step
and here some results:
