Node Red HTTP Post
Has anyone tried to create a flow in Node Red with their Spark core? The http post connects to my device but returns a value of -1. I am using the following url.
https://api.spark.io/v1/devices/50ff70065067545652160487/analogread?access_token=######&params=A0
Node Red Flow and result
Is analogread a `Spark.variable()?
I think he must have Tinker loaded on the core. That command should work OK with Tinker.
Yes, I’m using a HTTP Request GET command and a variable on the spark core to detect motion.
https://api.spark.io/v1/devices/53ff6d065067544813181187/motion?access_token=#######
It works well for me.
Hi @tinkerMike,
I think the problem you’re running into is ‘analogread’ is a spark.function, so it’s expecting a http POST request, and I’m guessing that http request is a GET.
David
@lightx - Have you tried a function where you pass the pin number? I can get the variable returned and that might be good enough for now but I was hoping to have a function to call.
There are both POST and GET Methods on the HTTP Request Node
HTTP Request Node
For the GET method, I successfully accessed a variable:
https://api.spark.io/v1/devices/50ff70065067545652160487/temperature?access_token=######
For the POST method, I unsuccessfully tried to access the Tinker app function:
@tinkerMike - the only way I found to work was to use exec since I couldn’t figure out how to pass arguments in the http request. Ive used something along the lines of
curl "https://api.spark.io/v1/devices/53ff6d065067544813181187/led?access_token=######" -d "args=on"
I was able to do it without using the exec block, see this flow:
