Node.js getting started tutorial
Want to step up from using shell/bash scripts or batch files with curl into using the Particle API from node.js? Don’t know where to get started?
There a new tutorial on getting started with node.js!
https://docs.particle.io/tutorials/learn-more/node-js/
Other techniques or examples you’d like added to the tutorial? Add them in the comments below.
Could you expand on file manipulation and transfer?
How would I write sensor data to a csv file? How about writing other file types, like transferring a file on an SD card on the device to the Node server?
