I am using Webhooks to call functions on my Photon which should then fade up some Neopixels (using the 7 LED Jewel).
For some reason, the function seems to be being called at random, without being triggered. I’m pretty sure this is something to do with my neopixels implementation as when using a regular LED to light up, it acts as it should, only lighting when triggered.
Any help greatly appreciated - code below:
#include "neopixel/neopixel.h"
// IMPORTANT: Set pixel COUNT, PIN and TYPE
#define PIXEL_COUNT 7
#define PIXEL_PIN D2
#define PIXEL_TYPE WS2812
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// note: if not specified, D2 is selected for you.
// Parameter 3 = pixel type [ WS2812, WS2812B, WS2811, TM1803 ]
// note: if not specified, WS2812B is selected for you.
// note: RGB order is automatically applied to WS2811,
// WS2812/WS2812B/TM1803 is GRB order.
// 800 KHz bitstream 800 KHz bitstream (most NeoPixel products ...
// ... WS2812 (6-pin part)/WS2812B (4-pin part) )
// 400 KHz bitstream (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// (Radio Shack Tri-Color LED Strip - TM1803 driver
// NOTE: RS Tri-Color LED's are grouped in sets of 3)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
Spark.function("order",order); // a POST request for "order" will reference order, defined below
Spark.function("cart",cart); // a POST request for "cart" will reference cart, defined below
Spark.function("spike",spike); // a POST request for "spike" will reference spike, defined below
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// call the below function when the POST request matches it - ORDER (Green)
int order(String command) {
colorWipe(strip.Color(0,255,0), 65);
delay(3000);
strip.show();
// call the below function when the POST request matches it - CART (Red)
int cart(String command) {
colorWipe(strip.Color(255,0,0), 65);
delay(3000);
strip.show();
// call the below function when the POST request matches it - SPIKE (blue)
int spike(String command) {
colorWipe(strip.Color(0,0,255), 65);
delay(3000);
strip.show();
colorAll(strip.Color(0, 0, 0), 50); // no colour
// Fill the dots one after the other with a color, wait (ms) after each one
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void colorAll(uint32_t c, uint8_t wait) {
uint16_t i;
for(i=0; i<strip.numPixels(); i++) {
strip.show();
delay(wait);
