Hi all not sure where to put this question so I’ve dumped it in general. Can you declare a string of neopixels as a matrix and a …string of neopixels in the same code? if so how?
so my matrix declaration is
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(15,10,1,1, PIXEL_PIN,
NEO_TILE_TOP + NEO_TILE_LEFT + NEO_TILE_ROWS + NEO_TILE_PROGRESSIVE +
NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT + NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
PIXEL_TYPE);
Then I proceed to scroll some text through it.
after I have scrolled the text (which is the time) I was wondering if I could make it throw a rainbow like the “standard” neopixel library example - and then go back to a matrix for more time updates.
I note that this type of thing is done before void setup()
Adafruit_NeoPixel strip = Adafruit_NeoPixel(3, PIN, WS2812B);
Is there any reason this can not go into void loop??
