So thanks to @bko I have been able to create the initial code for the project I’m working on. The second part that I would like to attempt (I know virtually nothing about this type of programming - TOTAL NEWBIE!!) is to be able to adjust the parameters of the program either via a webpage or via a LCD keypad such as this.
A few notes about the project. What I’m controlling is a relay shield that turns on one of two peristaltic dosing pumps. The pumps need to be able to run for very specific amounts of time, but may need to be adjusted over time. So it would be nice to be able to adjust the programming via a much more simple method than going into the spark builder every time.
Ideally the parameters to adjust would be as follows:
On time - day of week, hour, minute, second
run time - minutes, seconds
Manual On/Off Override
On a side note, it would be great to know if there was a way to measure the amount of liquid dispensed, but I’m not sure how you would go about that. The pump is supposed to dispense .6ml/min but the pumps are not always 100% accurate. This is definitely an after thought. I know there are flow meters, but I’m not sure I know of any flow meter that measures such small amounts
Here is the code, again, HUGE thanks to @bko for his help with this. And here is a link to his RTC Clock Library.
#include "SparkTime.h"
UDP UDPClient;
SparkTime rtc;
int RELAY1 = D0;
int RELAY2 = D1;
int RELAY3 = D2;
int RELAY4 = D3;
//Initilize the relay control pins as output
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
// Initialize all relays to an OFF state
digitalWrite(RELAY1, LOW);
digitalWrite(RELAY2, LOW);
digitalWrite(RELAY3, LOW);
digitalWrite(RELAY4, LOW);
rtc.begin(&UDPClient, "pool.ntp.org");
rtc.setTimeZone(-5); // gmt offset
rtc.setUseDST(true);
unsigned long currentTime = rtc.now();
static unsigned long stopTime = 0;
if (rtc.hour(currentTime)==0 && rtc.minute(currentTime)==17 && rtc.second(currentTime)==00) {
digitalWrite(RELAY1,HIGH);
stopTime = currentTime + (2); //one minute and ten seconds
if (currentTime >= stopTime) {
digitalWrite(RELAY1,LOW);
if (rtc.hour(currentTime)==0 && rtc.minute(currentTime)==17 && rtc.second(currentTime)==03) {
digitalWrite(RELAY2,HIGH);
digitalWrite(RELAY2,LOW);
delay(100);
