I’m struggling to get my Photon to automatically get the current date, and then compare it with a future date, leaving me with the remaining numbers. A countdown timer to Christmas day effectively, for the kids on a 2x1 DMD.
Might I ask the great coders how I manage to get the current day of the month (10), then subtract that from the target end date (25), then combine the result of 15 with the string text (15 sleeps until Christmas). I am currently just changing the number every morning, but would much like it to be automatic.
My code is below.
// Includes section
#include "SparkIntervalTimer/SparkIntervalTimer.h"
#include "SparkTime/SparkTime.h"
#include "DMD/DMD.h"
#include "DMD/SystemFont5x7.h"
#include "DMD/Arial_black_16.h"
#define DISPLAYS_ACROSS 2
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
IntervalTimer scanTimer;
UDP UDPClient;
SparkTime rtc;
String nowDay = "0";
unsigned long currentTime = rtc.now();
void ScanDMD()
dmd.scanDisplayBySPI();
void setup(void)
scanTimer.begin(ScanDMD, 5000, uSec);
dmd.clearScreen( true );
rtc.begin(&UDPClient, "pool.ntp.org");
rtc.setTimeZone(10); // GMT offset +10, Queensland Australia
void loop(void)
byte b;
// Message one section
nowDay = rtc.dayString(currentTime);
dmd.selectFont(Arial_Black_16);
char msgText1[] = " sleeps until Christmas";
//char msgText1[] = "15 sleeps until Christmas";
int msgText1Length = 25;
int targetDay = 25;
resultDays = (targetDay - nowDay);
remainingDays.concat(resultDays, msgText1)
dmd.drawMarquee(remainingDays,msgText1Length,(32*DISPLAYS_ACROSS)-1,0);
start=millis();
timer=start;
ret=false;
while(!ret){
if ((timer+30) < millis()) {
ret=dmd.stepMarquee(-1,0);
timer=millis();
// THE SECOND MESSAGE - This works, and everything under here.
char msgText2[] = "Merry Christmas Everyone";
int msgText2Length = 24;
dmd.drawMarquee(msgText2,msgText2Length,(32*DISPLAYS_ACROSS)-1,0);
long start=millis();
long timer=start;
boolean ret=false;
while(!ret){
timer=millis();
// More messages and stuff under here..
@KegRaider Here is how I would get the days left till Christmas.
Serial.begin(9600); // Open serial connection to report values to host
Serial.println("Starting up");
// Set time zone to Eastern USA
Time.zone(-4);
int day = Time.day();
int christmas = 25;
int SleepsUntilChristmas = (christmas - day);
Serial.print(SleepsUntilChristmas);
delay(5000);
Did you look at the Time functions? Time.day() will give you the day of the month. You should set Time.zone to the correct offset for your time zone first. I don’t think you need either SparkTime or SparkIntervalTimer libraries for what you’re trying to do.
@RWB, I’ll try and merge that into what I have and work on the squishing of the ‘SleepsUntilChristmas’ result with the text to scroll on the DMD.
@Ric, I needed the “SparkIntervalTimer” for the DMD panel, doesn’t work without it. I had all that working before I decided to try and get the counting down part to be automatic. I did link to the time functions, but thought I needed to see the NTP time. Oh well, live and learn.
I have this “rtc.setTimeZone(10); // GMT offset +10, Queensland Australia” in the void Setup part. I gather it’s not right? I shall change it back to “Time.zone(10);” and keep playing.
Cool, thanks @BKO. I’ll merge with the DMD code I have and report back when the photon is online to upload. I’m currently 1/2 way across the country (Australia) and have to wait until the house Christmas lights engage, powering the Photon. I was merely struggling to get my head around the date difference and concat functions. Looks like I don’t need the latter. I might have to use the smaller font to get it on the 64x16 LED array.
I did manage go get it to compile with the help of @RWB suggested code, which is a LOT further than what I was before. Thanks again!
Time.zone(10);
byte b;
int christmas = 25;
remainingDays = SleepsUntilChristmas + msgText1;
dmd.drawMarquee(remainingDays,msgFiveLength,(32*DISPLAYS_ACROSS)-1,0);
start=millis();
timer=start;
ret=false;
while(!ret){
timer=millis();
// bla bla, rest of stuff here.....
I just called the wife back home, and the display is scrolling “15 sleeps until Christmas”, plus a bunch of new pixel art screens I added. Totally stoked, thanks @RWB. I will examine the working of @bko code when I get home on Tuesday, so I can see in person what is happening with the panel. Pretty sure I will need to split the lines or scroll it.
