Need detailed datasheet M-SoM LTE-M/2G + Wi-Fi
I am working on a project in which we are using M-SoM LTE-M/2G + Wi-Fi for North America (M404) and looking for a datasheet where complete power details are mentioned regarding voltage and current consumption. The datasheet which is available in the particle website does not mentions maximum current consumption on each power rail. If anyone from the community can share the reference design document and detailed datasheet of this module, it will be helpful for us in designing our project.
Hi @Nilesh190697,
Does the power consumption section have the details you're interested in?
Also the power section lists the maximum current on the VCC (3V7) and 3V3 rails.
Also you should use the PM-BAT power module design as a reference for a power supply for a battery-operated design, even if you choose not to use the actual module. PM-DC can be used for designs without a battery.
