Need build/compile a$$i$t for Particle-Arducam source provided here:
Can you be more specific? Did you try anything and if so what?
I can only build/compile source to bin file, then flash, when the source requires no special library or include. As soon as the source requires a special library or include, I am lost.
I am on the platform of your choice
@mmay, assuming you have Windows, which version is it. Do you have the lastest Particle CLI installed?
Windows 10. I can install the latest Particle CLI.
@mmay, use the latest Windows installer for CLI which you can download from Particle.io.
Once you have it installed and tested, I’ll guide you from there.
ok thank you, i accept your guidance after work, unless you assist only during working hours , in which case, we must coordinate those hours. For now, I am off to work.
