Hi Sir, thanks a lot for your codes. i’ve modified your code and make it comunicated without handshaking.
Hi @syrinxtech
Thanks for sharing. This is very interesting.
I’m currently playing with rf95 too, but having some issue.
I want to send sensor data (motion sensor)from the sensor node to the gateway, but the data is too big for 1 byte so I divided it into two bytes and store in two variables and they will be reassembled in the gateway side. Then, I stored 9 bytes of all the sensor data in buf[]. At the gateway side, 5 bytes of the received data were correct, but the rest were wrong. What do you think the issue might be?
Thank you.
