Ran these tests on a Xenon with device os rc.27
I know, I know, @rickkas7 says that Threading is evil and we should be using FSM’s instead. :-). But I like threading, so here is my question.
I have 3 threads running at the same priority that are constantly toggling a different GPIO. The purpose is to show, using a digital logic analyzer, that the multitasking is doing a round robin between each thread every 1ms.
My initial code uses the SINGLE_THREADED_BLOCK to toggle the GPIO so that when the thread loses the cpu to another thread, its GPIO will always be low.
Here is the code:
SYSTEM_MODE(MANUAL);
SYSTEM_THREAD(ENABLED);
uint8_t d4 = D4;
uint8_t d5 = D5;
uint8_t d6 = D6;
os_mutex_t myMutex;
os_thread_t thread1;
os_thread_t thread2;
os_thread_t thread3;
void myThread(void *arg) {
uint8_t* value = (uint8_t*)arg;
Serial.println("printing from thread, woo hoo");
Serial.println(*value);
while (1) {
SINGLE_THREADED_BLOCK() {
// os_mutex_lock(myMutex);
digitalWrite(*value, HIGH);
delayMicroseconds(20);
digitalWrite(*value, LOW);
// os_mutex_unlock(myMutex);
waitFor(Serial.isConnected, 30000);
pinMode(D4, OUTPUT);
pinMode(D5, OUTPUT);
pinMode(D6, OUTPUT);
os_mutex_create(&myMutex);
Serial.println("hello world!!!");
os_thread_create(&thread1, "testThread1",OS_THREAD_PRIORITY_DEFAULT, myThread, &d4, 4096);
os_thread_create(&thread2, "testThread2",OS_THREAD_PRIORITY_DEFAULT, myThread, &d5, 4096);
os_thread_create(&thread3, "testThread3",OS_THREAD_PRIORITY_DEFAULT, myThread, &d6, 4096);
delay(100000);
The visible behavior on the logic analyzer looks perfect.
Now if I change the code to use a MUTEX rather than the SINGLE_THREADED_BLOCK, the behavior is not round robin and become inconsistent.
uint8_t d4 = D4;
uint8_t d5 = D5;
uint8_t d6 = D6;
os_mutex_t myMutex;
while (1) {
// SINGLE_THREADED_BLOCK() {
delay(100000);
Here is the logic analyzer trace.
Am I misundertanding how the mutex works or does this look like a bug?
