Msom filesystem size
I’m trying to find the actual MSoM user space filesystem size. I’ve read its 8MB running LittleFS with a POSIX wrapper. WIth overhead, I’m estimating ~6.5MB usable for offline caching. Does this seem correct? Thanks in advance.
The overhead is less than that, but also you should avoid completely filling the flash file system because it affects wear leveling, so 6.5 MB is a reasonable amount to use.
Thanks for the quick answer.
