hi all,
one more questions regarding the public libarry mqtt-tls provided by the great hirotakaster:
I’m sending 3 json strings via MQTT-TLS at 3 different rates:
mqtt_slow - every 4 hours
mqtt_fast - every 15 minutes
mqtt_onChange - whenever any of the basic parameter changes, I check them once a minute.
every time one of these timers saturates, I check if mqtt is connected. if not – enable TLS – connect – create json – client.publish()
What is the appropriate frequency to run the client.loop()? I’m currently running it every 10 seconds, but I don’t know if it’s using a lot of cellular data, or when is it actually required to be run.
Any input will be greatly appreciated.
thanks!
-R
