Just starting to evaluate the Monitor One and it looks like although the internal voltage divider on 0-10V input is using 0.1% resistors, the voltage reported by the unit (raw data coming from ADC) is off by about 5%. The voltage on the internal voltage divider node is spot on.
What is the reference voltage source for the ADC? Is it actually the 3.3V voltage supply?
If so, what is the officially recommended method for getting the accurate analog input reading on Monitor One?
