Modification needed in this code
Here is a code which is used to get dissolved oxygen values through a probe using arduino.
#include <avr/pgmspace.h>
#include <EEPROM.h>
#define DoSensorPin  A1    //dissolved oxygen sensor analog output pin to arduino mainboard
#define VREF 5000    //for arduino uno, the ADC reference is the AVCC, that is 5000mV(TYP)
float doValue;      //current dissolved oxygen value, unit; mg/L
float temperature = 25;    //default temperature is 25^C, you can use a temperature sensor to read it
#define EEPROM_write(address, p) {int i = 0; byte *pp = (byte*)&(p);for(; i < sizeof(p); i++) EEPROM.write(address+i, pp[i]);}
#define EEPROM_read(address, p)  {int i = 0; byte *pp = (byte*)&(p);for(; i < sizeof(p); i++) pp[i]=EEPROM.read(address+i);}
#define ReceivedBufferLength 20
char receivedBuffer[ReceivedBufferLength+1];    // store the serial command
byte receivedBufferIndex = 0;
#define SCOUNT  30           // sum of sample point
int analogBuffer[SCOUNT];    //store the analog value in the array, readed from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0,copyIndex = 0;
#define SaturationDoVoltageAddress 12          //the address of the Saturation Oxygen voltage stored in the EEPROM
#define SaturationDoTemperatureAddress 16      //the address of the Saturation Oxygen temperature stored in the EEPROM
float SaturationDoVoltage,SaturationDoTemperature;
float averageVoltage;
const float SaturationValueTab[41] PROGMEM = {      //saturation dissolved oxygen concentrations at various temperatures
14.46, 14.22, 13.82, 13.44, 13.09,
12.74, 12.42, 12.11, 11.81, 11.53,
11.26, 11.01, 10.77, 10.53, 10.30,
10.08, 9.86,  9.66,  9.46,  9.27,
9.08,  8.90,  8.73,  8.57,  8.41,
8.25,  8.11,  7.96,  7.82,  7.69,
7.56,  7.43,  7.30,  7.18,  7.07,
6.95,  6.84,  6.73,  6.63,  6.53,
6.41,
    Serial.begin(115200);
    pinMode(DoSensorPin,INPUT);
    readDoCharacteristicValues();      //read Characteristic Values calibrated from the EEPROM
   static unsigned long analogSampleTimepoint = millis();
   if(millis()-analogSampleTimepoint > 30U)     //every 30 milliseconds,read the analog value from the ADC
     analogBuffer[analogBufferIndex] = analogRead(DoSensorPin);    //read the analog value and store into the buffer
     analogBufferIndex++;
     if(analogBufferIndex == SCOUNT)
         analogBufferIndex = 0;
   static unsigned long tempSampleTimepoint = millis();
   if(millis()-tempSampleTimepoint > 500U)  // every 500 milliseconds, read the temperature
      //temperature = readTemperature();  // add your temperature codes here to read the temperature, unit:^C
   static unsigned long printTimepoint = millis();
   if(millis()-printTimepoint > 1000U)
      for(copyIndex=0;copyIndex<SCOUNT;copyIndex++)
        analogBufferTemp[copyIndex]= analogBuffer[copyIndex];
      averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF / 1024.0; // read the value more stable by the median filtering algorithm
      Serial.print(F("Temperature:"));
      Serial.print(temperature,1);
      Serial.print(F("^C"));
      doValue = pgm_read_float_near( &SaturationValueTab[0] + (int)(SaturationDoTemperature+0.5) ) * averageVoltage / SaturationDoVoltage;  //calculate the do value, doValue = Voltage / SaturationDoVoltage * SaturationDoValue(with temperature compensation)
      Serial.print(F(",  DO Value:"));
      Serial.print(doValue,2);
      Serial.println(F("mg/L"));
   if(serialDataAvailable() > 0)
      byte modeIndex = uartParse();  //parse the uart command received
      doCalibration(modeIndex);    // If the correct calibration command is received, the calibration function should be called.
boolean serialDataAvailable(void)
  char receivedChar;
  static unsigned long receivedTimeOut = millis();
  while ( Serial.available() > 0 )
    if (millis() - receivedTimeOut > 500U)
      memset(receivedBuffer,0,(ReceivedBufferLength+1));
    receivedChar = Serial.read();
    if (receivedChar == '\n' || receivedBufferIndex == ReceivedBufferLength)
	strupr(receivedBuffer);
	return true;
    }else{
        receivedBuffer[receivedBufferIndex] = receivedChar;
        receivedBufferIndex++;
  return false;
byte uartParse()
    byte modeIndex = 0;
    if(strstr(receivedBuffer, "CALIBRATION") != NULL)
        modeIndex = 1;
    else if(strstr(receivedBuffer, "EXIT") != NULL)
        modeIndex = 3;
    else if(strstr(receivedBuffer, "SATCAL") != NULL)
        modeIndex = 2;
    return modeIndex;
void doCalibration(byte mode)
    char *receivedBufferPtr;
    static boolean doCalibrationFinishFlag = 0,enterCalibrationFlag = 0;
    float voltageValueStore;
    switch(mode)
      case 0:
      if(enterCalibrationFlag)
         Serial.println(F("Command Error"));
      break;
      case 1:
      enterCalibrationFlag = 1;
      doCalibrationFinishFlag = 0;
      Serial.println();
      Serial.println(F(">>>Enter Calibration Mode<<<"));
      Serial.println(F(">>>Please put the probe into the saturation oxygen water! <<<"));
      Serial.println();
      break;
     case 2:
         Serial.println();
         Serial.println(F(">>>Saturation Calibration Finish!<<<"));
         Serial.println();
         EEPROM_write(SaturationDoVoltageAddress, averageVoltage);
         EEPROM_write(SaturationDoTemperatureAddress, temperature);
         SaturationDoVoltage = averageVoltage;
         SaturationDoTemperature = temperature;
         doCalibrationFinishFlag = 1;
      break;
        case 3:
            Serial.println();
            if(doCalibrationFinishFlag)
               Serial.print(F(">>>Calibration Successful"));
            else
              Serial.print(F(">>>Calibration Failed"));
            Serial.println(F(",Exit Calibration Mode<<<"));
            Serial.println();
        break;
int getMedianNum(int bArray[], int iFilterLen)
      int bTab[iFilterLen];
      for (byte i = 0; i<iFilterLen; i++)
	  bTab[i] = bArray[i];
      int i, j, bTemp;
      for (j = 0; j < iFilterLen - 1; j++)
	  for (i = 0; i < iFilterLen - j - 1; i++)
	    if (bTab[i] > bTab[i + 1])
		bTemp = bTab[i];
	        bTab[i] = bTab[i + 1];
		bTab[i + 1] = bTemp;
      if ((iFilterLen & 1) > 0)
	bTemp = bTab[(iFilterLen - 1) / 2];
      else
	bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
      return bTemp;
void readDoCharacteristicValues(void)
    EEPROM_read(SaturationDoVoltageAddress, SaturationDoVoltage);
    EEPROM_read(SaturationDoTemperatureAddress, SaturationDoTemperature);
    if(EEPROM.read(SaturationDoVoltageAddress)==0xFF && EEPROM.read(SaturationDoVoltageAddress+1)==0xFF && EEPROM.read(SaturationDoVoltageAddress+2)==0xFF && EEPROM.read(SaturationDoVoltageAddress+3)==0xFF)
      SaturationDoVoltage = 1127.6;   //default voltage:1127.6mv
      EEPROM_write(SaturationDoVoltageAddress, SaturationDoVoltage);
    if(EEPROM.read(SaturationDoTemperatureAddress)==0xFF && EEPROM.read(SaturationDoTemperatureAddress+1)==0xFF && EEPROM.read(SaturationDoTemperatureAddress+2)==0xFF && EEPROM.read(SaturationDoTemperatureAddress+3)==0xFF)
      SaturationDoTemperature = 25.0;   //default temperature is 25^C
      EEPROM_write(SaturationDoTemperatureAddress, SaturationDoTemperature);
I am unable to use this code in photon as the libraries are not available. The PROGMEM and EEPROM available on arduino while its not on particle. Can someone help me in modifying so that it can be used on particle board(photon).
here’s the link of the page where you can find the code more clearly:
https://www.dfrobot.com/wiki/index.php/Gravity:_Analog_Dissolved_Oxygen_Sensor_SKU:SEN0237
Seeing as there’s nothing really ‘special’ going on, it’s just a matter of replacing the memory storage for the Particle equivalent. There’s certainly EEPROM available, and with a bit of creativity/effort, you should be able to find a solution for your PROGMEM as well.
So, as always, what have you tried so far?
i could get the EEPROM part. But the PROGMEM am still having a look at the library avr/pgmspace.h .
ARM controllers don’t have a split memory space for PROGMEM so just remove the #include <avr/progmem.h> line as this is not an AVR controller.
For your analogRead() logic you need to consider that you are dealing with a 12bit ADC at 3.3V (compared to 10bit at 5V with Arduino)
hi,
I am working on the same project, and I have a similar issue that I could not find EEPROM library for particle photon. did you manage to get it to work?
Many thanks,
@msavooo, The Particle system firmware or API does not need a library in order to access the EEPROM, the functionality is built in. See the documentation here: https://docs.particle.io/reference/firmware/photon/#eeprom.
From the docs:
// EXAMPLE USAGE
// Write a value (2 bytes in this case) to the EEPROM address
int addr = 10;
uint16_t value = 12345;
EEPROM.put(addr, value);
// Write an object to the EEPROM address
addr = 20;
struct MyObject {
  uint8_t version;
  float field1;
  uint16_t field2;
  char name[10];
MyObject myObj = { 0, 12.34f, 25, "Test!" };
EEPROM.put(addr, myObj);
// SYNTAX
EEPROM.get(int address, object)
