I have a multi file app with
app.ino
module1.h
module1.cpp
module2.h
module2.cpp
I am new to this structure in C/C++ so have used declarations in the .h and functions and variables in .cpp files
I have globals vars in app.ino that are used in setup()
const int sizeOfVersion = 7;
const char firmwareVersion[sizeOfVersion] = “ZA011d”;
const char deviceModel[sizeOfVersion] = “fMonPM”;
unsigned char eepSignature = firmwareVersion[5];
I wish to also use these in module1.cpp so I added this
extern unsigned char eepSignature;
to the module1.cpp - and it works okay.
If I then add
extern const char firmwareVersion;
to module1.cpp.
I have a defined struct in the same .cpp
struct { // common struct for attributes stored in EEPROM
char attributeName[sizeOfAttributeName];
char attributeValue[largestAttributeValue];
time_t lastChanged;
} attributes;
and want to do this
sprintf(attributes.attributeValue, “%s”, firmwareVersion); // firmware
I get this error
/firmware/user/…/wiring/inc/spark_wiring_eeprom.h:151:0: undefined reference to “firmwareVersion”
What am I missing here ?
shanevanj:
If I then add
firmwareVersion
is defined as const char[]
so your extern
reference should also be of this or a compatible type (e.g. extern const char* firmwareVersion;
shanevanj:
I get this error
You are missing the additional notes that are given in the raw error message output that would probably provide more clues about the reason for this error.
Thanks - if i try this change, then the error becomes
Raw Error at bottom of list
…/…/…/build/target/user/platform-14-mlibuser.a(EEP.o): In function eepromCreateDataTable()': src/EEP.cpp:252: undefined reference to
firmwareVersion’
The line number is the closing brace of the function that contains the reference to ‘firmwareVersion’ (not the line number of the variable usage)
Raw for EEP.cpp (no errors at the end of the block)
new -std=gnu++11 -c -o …/build/target/user/platform-14-msrc/EEP.o src/EEP.cpp
What IDE are you using?
I’d expect some more build output that may help pinpoint the root cause.
If you can share a zip file or with Web IDE a SHARE THIS REVISION link of your project (if you want in a DM) it may be easier to get to the bottom of it.
Thanks I am using the web IDE - havn’t got around to installing the workbench yet.
I’ll DM you.
I haven’t fully got to the bottom of why this plays a role, but when you remove the extern
definitions from your EEP.cpp
and put this block
extern const char firmwareVersion[];
extern const char deviceModel[];
into your EEP.h
file the project builds for me.
I really appreciate your time on this - I am still getting an error
…/…/…/build/target/user/platform-14-mlibuser.a(EEP.o): In function unsigned char const& EEPROMClass::put<unsigned char>(int, unsigned char const&)': /firmware/user/../wiring/inc/spark_wiring_eeprom.h:151: undefined reference to
firmwareVersion’ collect2: error: ld returned 1 exit status …/…/…/build/module.mk:232: recipe for target ‘target/workspace.elf’ failed make[1]: Leaving directory ‘/firmware/modules/xenon/user-part’ make[1]: *** [target/workspace.elf] Error 1 …/build/recurse.mk:11: recipe for target ‘modules/xenon/user-part’ failed make: *** [modules/xenon/user-part] Error 2
I’ll DM you a link to the working revision I have
Thanks - working now I put the block into .cpp instead of .h - I’ll soak test tonight and let you know how it goes.
