Math.h in Spark Dev [SOLVED]
I'm porting a library, using Spark Dev... having trouble with Math.h
I have tried:
#include <Math.h>
and
#include "Math.h"
Cannot get it to compile in the cloud...
Am I missing something?
Math.h: No such file or directory
You need a lowercase “m” in the name.
http://docs.spark.io/firmware/#other-functions-math
yeah tried that too...
I get:
and no other compiler errors...
What math function are you missing?
Quite a few of the standard math functions are already included via application.h direct or indirectly.
But when I try #include "math.h" in Spark Dev, my code compiles, so your above message might originate from some of your other code or “disallowed” files in your project folder (only .INO, .CPP & .H should be there).
just these few:
sin( )
cos( )
tan( )
acos( )
fabs( )
yup... I deleted keywords.txt
thanks!
side question…
Is there no available implementation of keywords in Spark Dev IDE?
I don’t have Spark Dev IDE here, but these all worked for (on floats) in the webIDE. I think your problem might be elsewhere.
This might be a question @suda could answer best.
yeah, the presence of my keywords.txt file was annoying the compiler... all better now.
Do you mean highlighting functions like sin()?
Sort of, I meant similar to the arduino implementation where you can define special keywords that are highlighted differently in the IDE's editor...
Your IDE does a nice job with highlighting functions constants, etc, so not really as important as other things, I suppose.
I'm just dealing with my own paradigm shift here...
