Manipulating and Splitting incoming I2C string to be sent along
Hey everyone I am working with a difficult string coming in From a LoRa device via I2C and I need to split it apart into 5 different segments and them forward them off to Thingsboard …the partial code is below
snprintf(mqttPub, sizeof(mqttPub), "{\"ipstring\":%s}",ipstring);
Serial.println(mqttPub);
Particle.publish("Sensor_Data",mqttPub);
 //Serial.println(mqttPub);
    // Send payload
psClient.publish("v1/devices/me/telemetry", mqttPub);               // Topic, payload
 blinkLED();
  //cnt=0;
  //pub=1;
void serverConnect(void)
    while (!psClient.connected())
        Serial.println("serverConnect(): Attempting to connect to Thingsboard server");
        if (psClient.connect("Photon", TOKEN, NULL))                    // ClientID, User, PW
            Serial.println("serverConnect(): Connected");
            return;
        else
            Serial.println("serverConnect(): Connection failed, retry in 3 seconds");
        delay(3000);
The output form the LoRa device is this {“ipstring”:101592_23_512_42496_50432}
@jade7272, you can do a search for “strtok” which is the perfect tool for parsing strings. You will find lots of examples in the community.
http://www.cplusplus.com/reference/cstring/strtok/
Thanks having a look now
@jade7272, as @ScruffR might point out, you can also use scanf():
http://www.cplusplus.com/reference/cstdio/scanf/
Thanks Guys …This will help …Just need to put in special characters in the incoming string to separate and send along
