Making API call from Windows 7 64bit
From the “Annotated examples” I want to “control LEDs over the net” but I dont know how to make API call using my windows7 64bit system. I downloaded cURL for Windows 64 bit (http://curl.haxx.se/download/curl-7.33.0-win64-ssl-sspi.zip) and placed it in c:\windows\systems32. Now I am able to use cURL commands from the command line. I actually like to use batch files so I created a text file and renamed it to *.bat. In the batch file I placed following text
curl https://api.spark.io/v1/devices/<my_device_id>/led -d access_token=<my_token> -d params=l1,HIGH"
but the command doesn’t work and I get a SSL certificate check error. I was able to control the LEDs correctly using this handy webpage http://jflasher.github.io/spark-helper/
Can anyone advise?
I got it working. First of all the format of the curl command is:
curl [options] <URL>
And you need to turn of the certification checking using the -k option.
curl -k -d params=l1,HIGH -d access_token=<my_token> https://api.spark.io/v1/devices/<my_device_id>/led
Thanks @jrsikken for sharing the fix! We’ll update the documentation to include the -k flag.
Hi, thanks for the tips. I got my access_token and sent that along as a parameter, but then when I try to use curl to POST to my device I get a string of html for a 502 Bad Gateway page. Any ideas on what I’m doing wrong?
@Elijah can you share the curl request that you’re making? just obscure the device ID and access token.
curl -k -d pin=D7 -d level=HIGH -d access_token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx https://api.sprk.io/v1/devices/[device_id]
and also
curl -k -d pin=D7 -d level=HIGH -d access_token=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx https://api.sprk.io/v1/devices/[device_id]/led
@Elijah not sure if this is causing your problem, but you should only send in one data field. for example:
curl https://api.spark.io/v1/devices/0123456789abcdef01234567/led \
  -d access_token=1234123412341234123412341234123412341234 \
  -d params=l1,HIGH
No, passing -d params=D7,HIGH instead of -d pin=D7 -d level=HIGH is returning the same 502 error page html.
Oh I see the issue - you’re using api.sprk.io instead of api.spark.io. This is from our old pre-launch servers.
OK, so now I am getting back a set of return values: name, id, last_app, connected, return_value but they don’t seem to depend on what I post with params; and the LED isn’t turned on.
It’s alright, it’s late, I’ll have to look into it more later =]
