@avidan @peekay123 we’ll give this a shot in the office tomorrow!
@kanetron, do you want the code?
@peekay123 Great work!
I have 2 x 64x32 panels so could this work with the 124 x 32 pixel panel?
I assume there shouldn’t be much of an issue running this on a single 64x32 panel.
Do the GIF’s need to be in any special format for best results?
@RWB, the memory requirements may be the killer with that size. The code will compile but when it runs, if not enough memory is available, it will SOS. I’ll try it tonight. The GIFs need to be the same size as the display or smaller and can be either a single GIF or an animated GIF. Animation “speed” (ie frames/s) will be limited by the refresh rate of the panel which is lowered by the larger display.
@peekay123 yes! my email is kane at root.vc
@kanetron, just testing a couple more things and it’ll be on its way!
@kanetron, I sent you an email with some goodies
Looks Sweet!
Shoot a video once you have the animation you guys are happy with up and running?
Are you running the Piecade on a RasPi on there? I just recently gave that a try and the amount of games you can play once setup is crazy!
