LSM 330 code working on Core but not on Photon [SOLVED]
Below is the source code for LSM330 that runs and works on a core. The same code compiles perfectly well for Photon. But when run on Photon, it makes the LED go a solid cyan and there is no output on the serial port. Basically the Photon hangs. What do I need to do differently?
#include "application.h"
// LSM330D I2C address
// Accelerometer = 001100xb
#define LSM330D_A_ADDR0     0b00011000  // SA0=0(GND)
#define LSM330D_A_ADDR1     0b00011001  // SA0=1(VDD)
// gyro = 110101xb
#define LSM330D_G_ADDR0     0b01101010  // SA0=0(GND)
#define LSM330D_G_ADDR1     0b01101011  // SA0=1(VDD)
byte addr_A = LSM330D_A_ADDR0;
byte addr_G = LSM330D_G_ADDR0;
// LSM330D Register Map
// Acceleromete
#define LSM330D_CTRL_REG1_A     0x20
#define LSM330D_CTRL_REG2_A     0x21
#define LSM330D_CTRL_REG3_A     0x22
#define LSM330D_CTRL_REG4_A     0x23
#define LSM330D_CTRL_REG5_A     0x24
#define LSM330D_OUT_X_L_A       0x28
#define LSM330D_OUT_X_H_A       0x29
#define LSM330D_OUT_Y_L_A       0x2A
#define LSM330D_OUT_Y_H_A       0x2B
#define LSM330D_OUT_Z_L_A       0x2C
#define LSM330D_OUT_Z_H_A       0x2D
// gyro
#define LSM330D_WHO_AM_I_G      0x0F
#define LSM330D_WHOAMI_G_VAL    0xD4
#define LSM330D_CTRL_REG1_G     0x20
#define LSM330D_CTRL_REG2_G     0x21
#define LSM330D_CTRL_REG3_G     0x22
#define LSM330D_CTRL_REG4_G     0x23
#define LSM330D_CTRL_REG5_G     0x24
#define LSM330D_OUT_X_L_G       0x28
#define LSM330D_OUT_X_H_G       0x29
#define LSM330D_OUT_Y_L_G       0x2A
#define LSM330D_OUT_Y_H_G       0x2B
#define LSM330D_OUT_Z_L_G       0x2C
#define LSM330D_OUT_Z_H_G       0x2D
void writeReg(byte addr, byte reg, byte value)
    Wire.beginTransmission(addr);
    Wire.write(reg);
    Wire.write(value);
    Wire.endTransmission();
void readReg(byte addr, byte reg, byte len, byte *data)
    byte i;
    Wire.write(reg | 0x80);         // bit7-ON (subaddress updating)
    Wire.requestFrom(addr, len);
    for (i = 0; i < len; i++){
        if (Wire.available()){
            *data = Wire.read();
        } else {
            *data = 0x00;
        data ++;
    byte data;
    Wire.begin();
//    pinMode(22,OUTPUT);
//    digitalWrite(22,HIGH);
//    pinMode(23,OUTPUT);
//    digitalWrite(23,HIGH);
    readReg(addr_G, LSM330D_WHO_AM_I_G, 1, &data);
    if (data != LSM330D_WHOAMI_G_VAL)
        Serial.print("Failed to detect LSM330DLC - 1 ");
        Serial.print(LSM330D_WHOAMI_G_VAL);
        Serial.print("   ");
        Serial.println(data);
        delay(2000);
        Serial.print("Failed to detect LSM330DLC - 2 ");
        Serial.print("   ");
        delay(2000);
        Serial.print("Failed to detect LSM330DLC - 3 ");
        Serial.print("   ");
        delay(2000);
        Serial.print("Failed to detect LSM330DLC - 4 ");
        Serial.print("   ");
        delay(2000);
        Serial.print("Failed to detect LSM330DLC - 5 ");
        Serial.print("   ");
        delay(2000);
//        while (1);
    // Accelerometer
    writeReg(addr_A, LSM330D_CTRL_REG1_A, 0b10010111);
    writeReg(addr_A, LSM330D_CTRL_REG2_A, 0b00000000);
    writeReg(addr_A, LSM330D_CTRL_REG3_A, 0b00001000);
    writeReg(addr_A, LSM330D_CTRL_REG4_A, 0b00001000);  // +/-2G (1mg/digt)
    writeReg(addr_A, LSM330D_CTRL_REG5_A, 0b01000000);
    // Gyro
    writeReg(addr_G, LSM330D_CTRL_REG1_G, 0b00001111);
    writeReg(addr_G, LSM330D_CTRL_REG2_G, 0b00000000);
    writeReg(addr_G, LSM330D_CTRL_REG3_G, 0b00000000);
    writeReg(addr_G, LSM330D_CTRL_REG4_G, 0b00000000);  // 250dps (8.75mdps/digit)
    writeReg(addr_G, LSM330D_CTRL_REG5_G, 0b00000000);
    byte Buffer[6];
    short AccelRaw_x, AccelRaw_y, AccelRaw_z;
    short GyroRaw_x,  GyroRaw_y,  GyroRaw_z;
    float Accel_x, Accel_y, Accel_z;
    float Gyro_x,  Gyro_y,  Gyro_z;
    // Accelerometer
    readReg(addr_A, LSM330D_OUT_X_L_A, 6, Buffer);
    AccelRaw_x = ((Buffer[1] << 8) | Buffer[0]);
    AccelRaw_x = AccelRaw_x >> 4;
    Accel_x = AccelRaw_x * 0.001;
    AccelRaw_y = ((Buffer[3] << 8) | Buffer[2]);
    AccelRaw_y = AccelRaw_y >> 4;
    Accel_y = AccelRaw_y * 0.001;
    AccelRaw_z = ((Buffer[5] << 8) | Buffer[4]);
    AccelRaw_z = AccelRaw_z >> 4;
    Accel_z = AccelRaw_z * 0.001;
    // Gyro
    readReg(addr_G, LSM330D_OUT_X_L_G, 6, Buffer);
    GyroRaw_x = ((Buffer[1] << 8) | Buffer[0]);
    Gyro_x = GyroRaw_x * 0.00875;
    GyroRaw_y = ((Buffer[3] << 8) | Buffer[2]);
    Gyro_y = GyroRaw_y * 0.00875;
    GyroRaw_z = ((Buffer[5] << 8) | Buffer[4]);
    Gyro_z = GyroRaw_z * 0.00875;
    // output serial
    Serial.print("Millis: ");
    Serial.print(millis());
    Serial.print("Accel:\t");
    Serial.print(AccelRaw_x);
    Serial.print(",\t");
    Serial.print(Accel_x);
    Serial.print(AccelRaw_y);
    Serial.print(Accel_y);
    Serial.print(AccelRaw_z);
    Serial.print(Accel_z);
    Serial.print("|Gyro:\t");
    Serial.print(GyroRaw_x);
    Serial.print(Gyro_x);
    Serial.print(GyroRaw_y);
    Serial.print(Gyro_y);
    Serial.print(GyroRaw_z);
    Serial.print(Gyro_z);
    Serial.print("\n");
//    delay(500);
Could this open issue fit your symptoms?
https://github.com/spark/firmware/issues/713
Bingo!!! Worked as soon as the pull-ups were connected. Excellent!
This is an important (and frustrating) issue that I spent much time on. You might want to link it to other related posts as well.
Please mark as solved.
The I2C bus mandates use of pullup resistors - not using these is a design for failure.
As @mdma already said, I2C demands pull-ups and it's is documented too
https://docs.particle.io/reference/firmware/photon/#wire-i2c-
I²C - Wikipedia
Well - if I run the code on the core without connecting the LSM330 or any pull-up resistors - using just the core, it works. I am doing this to test in a stepwise. Of course, I get - LSM not detected.
However, running the same code on Photon hangs it. I am sure there must be a way to gracefully exit whatever it causing it to hang. :neutral_face:
Of course, this is exactly the reason for the open issue linked above, so that the device will survive even if it’s used against its design rules, if it can.
