Low-level AssetTracker2 u-blox GPS hacking
If you want to play around with the low-level features of the u-blox M8 GPS in the AssetTracker v2, you should definitely download the free u-blox u-center for Windows.
Then flash this firmware to your Electron, which makes the Electron USB serial port a pass-through to the GPS, so you can directly manipulate the GPS from u-center.
#include "Particle.h"
SYSTEM_MODE(MANUAL);
	Serial1.begin(9600);
	pinMode(D6, OUTPUT);
	digitalWrite(D6, LOW);
	while(Serial.available()) {
		Serial1.write(Serial.read());
	while(Serial1.available()) {
		Serial.write(Serial1.read());
You can see all of the data coming out of the GPS, and try out all of the commands you can send to it in a graphical UI. Neat!
Thank you Rick!
