C4ās return is quite long⦠see if you can get that ground connected more directly to the Coreās GND.
As a general practice, the planes under L1 should be split in the middle with a gap, vs. shifted to one side like you have it. Or better yet, remove the ground plane under the inductor completely. Unless the inductor is a shielded type, then it doesnāt matter much, but Iād still gap it center it just because I might not be able to buy a shielded type of inductor down the road. The ground plane on the bottom under the inductor is not serving a purpose for heat or much for current either, so you could clear it away there as well. Do some research on this as well, this is kind of stuff I do because Iāve run into issues in the past during EMI testing and SMPS tuning. YMMV
C4 return path is GND pin on header --> bottom plane --> GND pin on spark. Itās not that long? I can place it under the spark core though and it will be shorter.
Ahh, ok⦠didnāt see that GND pin on the 3 pin connector. Thatās not so bad, but ideally you want both legs of the cap to be between the the input connections and connections to the spark core.
If you have a reference design, definitely go for that first. Itās shielded anyway, so no worries⦠just a more expensive part. Reference designs are a good place to start, but also be cautious as they are not always going to give you what you need.
Donāt be afraid to stitch your GND planes from top to bottom a bit more⦠itās basically free.
yes i am dutch
would love to help you, i am great in copy pasting code and troubleshooting stuff, not so much in writing blank code.
still happy to help.
Not only does it look greatā¦I think you have done an awesome job in the short time that you have been working on this projectā¦Just simply very well doneā¦Wish I have the electronic and programming skills to help push it down the road to completion just a bit faster as Iām very eager to try it outā¦
Glad I didnāt place my order for the BrewPi shield tonight before looking at this thread.
Is it too late to start looking at using the Photon instead of the Core?
Because it comes with enclosure and all, I decided to call it the BrewPi Spark, instead of BrewPi Spark Shield.
I hope thatās okay, because every unit will have a spark core inside I thought it was appropriate.
