Local ip is 0.0.0.0 when #include "spark_disable_cloud.h"
As the topic says the Cores local ip is getting set to 0.0.0.0 when i try to disconnect from the cloud. Is there a way to choose the Cores ip manually?
Here is the code i am using to get the error:
#include "application.h"
UDP Udp;
char myIpString[24];
    Spark.connect();
    //setup udp socket
    Udp.begin(1000);
        Serial.println(Network.localIP());
            IPAddress myIp = Network.localIP();
    sprintf(myIpString, "%d.%d.%d.%d", myIp[0], myIp[1], myIp[2], myIp[3]);
    Spark.variable("ipAddress", myIpString, STRING);
Hi @simoher
I think this is a known issue that has been fixed in the latest master but not in the webIDE. The issue is that ip_config is not updated.
It looks like a work-around until this comes to the Sparkulator webIDE is to put a call to
netapp_ipconfig(&ip_config);
in your setup() after you connect.
