Hi all, I was setting up local cloud for spark core, following the instruction in this post Tutorial: Local Cloud 1st Time instructions [01 Oct 15] - Tutorials - Particle
I was stuck at the "spark setup" step. When I ran "spark setup", it gave me this
Setup your account
Could I please have an email address? albert.pang@me.com
and a password? ********
Trying to login...
Could not get new access token: server_error
login error: server_error
Error setting up your core: Unable to login or create a new account
Tried repeating the procedure a couple of times but no luck. At the end, I stepped through the spark-cli code and found that it actually successfully went to the server to try login first. Server said there were no users created and returned an error "login error: server_error" (users directory is empty so it never read any file into the user profile array). I expected spark-cli it to then ask me to create a new account, but it never did, instead, it just exited with the above error message. I checked the config file and saw that the access_token written to it is actually "Login error: server_error"
Stepping through the code, I think it's because of the login function in spark-cli ApiClient.js:
login: function (client_id, user, pass) {
var that = this;
return this.createAccessToken(client_id, user, pass).then(function(resp) { console.log("Got an access token! " + resp.access_token); that._access_token = resp.access_token; return that._access_token; }).catch(function (err) { console.error("login error: ", err); return("Login Failed: " + err); });},
After it logs the error in the console, it actually returns "Login Failed: ..." to the caller. The caller is in SetupCommand.js:
when(loginDone).then( function (token) { if (username) { settings.override(null, "username", username); }
//login success tmp.resolve(token); }, function () {
var username = creds[0]; if (!username || (username == '') || (!utilities.contains(username, "@")) || (!utilities.contains(username, "."))) { tmp.reject("Username must be an email address."); return; }
console.log("Login failed, Lets create a new account!");
It went into the success function (the one with the comment "//login success" in it), rather than the failure function which is where the code for creating a new account is.
I changed the return statement in the login function to be a reject call, like so:
var that = this;
return this.createAccessToken(client_id, user, pass).then(function(resp) { console.log("Got an access token! " + resp.access_token); that._access_token = resp.access_token; return that._access_token; }).catch(function (err) { console.error("login error: ", err); reject( error ); // return("Login Failed: " + err); });},
After that it went into the code for creating a new account as I would have expected it to and I was able to move on. I took the spark-cli code and spark-server code by git clone. So that should be the latest as of yesterday.
Searching through the forum, I don't seem to see anyone having problem with spark setup. So I wondered why only me got this problem. Am I using the wrong version of the code or have I perhaps missed some steps when setting up the server to first create users before calling "spark setup"?
Any ideas? Thanks in advance!
Cheers,
Albert
