I have been trying to build locally with the develop branch and my user app, but I have been getting the below errors. All the errors pertain to functions within my code.
Does anyone know why the functions do not compile?
Heres my app.cpp code:
#include "application.h"
#define centerPin 4 //Center switch for tray alignment
#define motorPin4 P1S0 // Orange - 28BYJ48 pin 4 Stepper motor control
#define motorPin3 P1S1 // Yellow - 28BYJ48 pin 3 Stepper motor control
#define motorPin2 P1S2 // Pink - 28BYJ48 pin 2 Stepper motor control
#define motorPin1 P1S3 // Blue - 28BYJ48 pin 1 Stepper motor control
boolean centerStatus = FALSE;
int motorSpeed = 1700;
int currStep = 1;
//SYSTEM_MODE(SEMI_AUTOMATIC);
pinMode(centerPin, INPUT_PULLUP); //Battery volage readings
pinMode(motorPin1, OUTPUT); //stepper mortor pin
pinMode(motorPin2, OUTPUT); //stepper mortor pin
pinMode(motorPin3, OUTPUT); //stepper mortor pin
pinMode(motorPin4, OUTPUT); //stepper mortor pin
setMotor(0,0,0,0,0); //Turns stepper motor off
attachInterrupt(centerPin, centerTriggered, FALLING);
while (centerStatus == false){
nextStep();
void loop(void) {
void nextStep(){
switch (currStep) {
case 1:
setMotor(1,0,0,0,motorSpeed);
break;
case 2:
setMotor(1,1,0,0,motorSpeed);
break;
case 3:
setMotor(0,1,0,0,motorSpeed);
break;
case 4:
setMotor(0,1,1,0,motorSpeed);
break;
case 5:
setMotor(0,0,1,0,motorSpeed);
break;
case 6:
setMotor(0,0,1,1,motorSpeed);
break;
case 7:
setMotor(0,0,0,1,motorSpeed);
break;
case 8:
setMotor(1,0,0,1,motorSpeed);
break;
currStep++;
if(currStep > 8){
currStep = 1;
void setMotor(int8_t pin1, int8_t pin2, int8_t pin3, int8_t pin4, int theDelay){
if(pin1 == 1){
digitalWrite(motorPin1, HIGH);
} else {
digitalWrite(motorPin1, LOW);
if(pin2 == 1){
digitalWrite(motorPin2, HIGH);
} else {
digitalWrite(motorPin2, LOW);
if(pin3 == 1){
digitalWrite(motorPin3, HIGH);
} else {
digitalWrite(motorPin3, LOW);
if(pin4 == 1){
digitalWrite(motorPin4, HIGH);
} else {
digitalWrite(motorPin4, LOW);
delayMicroseconds(theDelay);
void centerTriggered(){
centerStatus = true;
applications/testing/app.cpp: In function 'void setup()':
applications/testing/app.cpp:23:23: error: 'setMotor' was not declared in this s
cope
applications/testing/app.cpp:24:32: error: 'centerTriggered' was not declared in
this scope
applications/testing/app.cpp:27:18: error: 'nextStep' was not declared in this s
cope
nextStep();
applications/testing/app.cpp: In function 'void nextStep()':
applications/testing/app.cpp:39:40: error: 'setMotor' was not declared in this s
cope
applications/testing/app.cpp:64:25: error: 'setMotor' was not declared in this s
cope
make[2]: *** [../build/target/user/platform-8-m/applications/testing/application
s/testing/app.o] Error 1
make[1]: *** [user] Error 2
make: *** [c:/firmware/modules/photon/user-part/makefile] Error 2
