Local building for Core+Photon
Thank you for the two answers.
Here the tests I've conducted so far.
Configuration
Tool-chain and SDK located at
/Users/ReiVilo/Library/embedXcode/gcc-arm-none-eabi-4_9-2015q2 /Users/ReiVilo/Library/embedXcode/Particle-new with firmware-latest branch
Projects are located at
/Users/ReiVilo/Desktop/particle-1 /Users/ReiVilo/Desktop/particle-2 /Users/ReiVilo/Desktop/particle-3
Test 1
The particle-1 folder contains
/Users/ReiVilo/Desktop/particle-1/LocalLibrary.cpp /Users/ReiVilo/Desktop/particle-1/LocalLibrary.h /Users/ReiVilo/Desktop/particle-1/main.cpp
Test 1a
  • Launch cd ~/Library/embedXcode/Particle-new/firmware/modules
  • Launch make v=1 GCC_ARM_PATH=/Users/ReiVilo/Library/embedXcode/gcc-arm-none-eabi-4_9-2015q2/bin/ COMPILE_LTO=n PLATFORM_ID=6 APPDIR=/Users/ReiVilo/Desktop/particle-1 TARGET_DIR=/Users/ReiVilo/Desktop/particle-1/Builds TARGET_FILE=embeddedcomputing clean all program-dfu > ~/Desktop/particle-1/1a.txt
  • Result: OK.
Test 1b
Change the number of blinks, e.g. blink(myLED, 1, 333); for blink(myLED, 2, 333);
  • Launch make v=1 GCC_ARM_PATH=/Users/ReiVilo/Library/embedXcode/gcc-arm-none-eabi-4_9-2015q2/bin/ COMPILE_LTO=n PLATFORM_ID=6 APPDIR=/Users/ReiVilo/Desktop/particle-1 TARGET_DIR=/Users/ReiVilo/Desktop/particle-1/Builds TARGET_FILE=embeddedcomputing program-dfu > ~/Desktop/particle-1/1b.txt
  • Result: NOK
Omitting clean all fails: old code is kept, new code not taken into account. The LED still blinks once, not twice.
Test 1c
  • Launch make v=1 GCC_ARM_PATH=/Users/ReiVilo/Library/embedXcode/gcc-arm-none-eabi-4_9-2015q2/bin/ COMPILE_LTO=n PLATFORM_ID=6 APPDIR=/Users/ReiVilo/Desktop/particle-1 TARGET_DIR=/Users/ReiVilo/Desktop/particle-1/Builds TARGET_FILE=embeddedcomputing clean all program-dfu > ~/Desktop/particle-1/1c.txt
  • Result: OK.
Question 1
Is clean all compulsory? Why to build the whole framework each time? Why to upload 3 packages each time, when only the latest one changes?
Downloading to address = 0x08020000, size = 249148 Downloading to address = 0x08060000, size = 169036 Downloading to address = 0x080a0000, size = 2272
Question 2
How to get rid of those messages?
fatal: Not a git repository (or any of the parent directories): .git
Question 3
What is the meaning of COMPILE_LTO=n, which is not documented at device-os/docs/build.md at develop · particle-iot/device-os · GitHub?
Test 2
The particle-2 folder contains
/Users/ReiVilo/Desktop/particle-2/blink.ino /Users/ReiVilo/Desktop/particle-2/LocalLibrary.cpp /Users/ReiVilo/Desktop/particle-2/LocalLibrary.h /Users/ReiVilo/Desktop/particle-2/main.cpp
Test 2a
Sketch uses an .ino extension. main.cpp mentions #include "blink.ino"
  • Launch make v=1 GCC_ARM_PATH=/Users/ReiVilo/Library/embedXcode/gcc-arm-none-eabi-4_9-2015q2/bin/ COMPILE_LTO=n PLATFORM_ID=6 APPDIR=/Users/ReiVilo/Desktop/particle-2 TARGET_DIR=/Users/ReiVilo/Desktop/particle-2/Builds TARGET_FILE=embeddedcomputing clean all program-dfu > ~/Desktop/particle-2/2a.txt
  • Result: OK.
Question 1, Question 2, Question 3
Same as per Test 1.
Test 2b
  • Launch make v=1 GCC_ARM_PATH=/Users/ReiVilo/Library/embedXcode/gcc-arm-none-eabi-4_9-2015q2/bin/ COMPILE_LTO=n PLATFORM_ID=6 APPDIR=/Users/ReiVilo/Desktop/particle-2 TARGET_DIR=/Users/ReiVilo/Desktop/particle-2/Builds TARGET_FILE=embeddedcomputing program-dfu > ~/Desktop/particle-2/2b.txt
  • Result: NOK.
Test 2c
Separating building and linking from uploading. Uploading done through USB or OTA.
  • Launch make v=1 GCC_ARM_PATH=/Users/ReiVilo/Library/embedXcode/gcc-arm-none-eabi-4_9-2015q2/bin/ COMPILE_LTO=n PLATFORM_ID=6 APPDIR=/Users/ReiVilo/Desktop/particle-2 TARGET_DIR=/Users/ReiVilo/Desktop/particle-2/Builds TARGET_FILE=embeddedcomputing clean all > ~/Desktop/particle-2/2c.txt
  • Launch particle flash ABCDEFGHIJKLMNOPQRSTUVWX /Users/ReiVilo/Desktop/particle-2/Builds/embeddedcomputing.bin
  • Result: Success rate = 60%.
Connection fails although the LED pulses cyan and the board is listed as online. Error message is
Flash device failed
[object Object]
  • Launch particle flash --usb /Users/ReiVilo/Desktop/particle-2/Builds/embeddedcomputing.bin
  • Result: OK.
Question 4
How to upload the program OTA with success rate = 100%?
Test 3
The particle-3 folder contains
/Users/ReiVilo/Desktop/particle-3/blink.ino /Users/ReiVilo/Desktop/particle-3/LocalLibrary.cpp /Users/ReiVilo/Desktop/particle-3/LocalLibrary.h /Users/ReiVilo/Desktop/particle-3/main.cpp /Users/ReiVilo/Desktop/particle-3/Particle_fast.mk
Particle_fast.mk include a variable definition MY_IDE, which is tested on main.cpp and blink.ino
CPPFLAGS += -DMY_IDE=310 CFLAGS += -DMY_IDE=310
  • Launch make v=1 GCC_ARM_PATH=/Users/ReiVilo/Library/embedXcode/gcc-arm-none-eabi-4_9-2015q2/bin/ COMPILE_LTO=n PLATFORM_ID=6 APPDIR=/Users/ReiVilo/Desktop/particle-3 TARGET_DIR=/Users/ReiVilo/Desktop/particle-3/Builds TARGET_FILE=embeddedcomputing USER_MAKEFILE=Particle_fast.mk clean all program-dfu > ~/Desktop/particle-3/3a.txt
  • Result: NOK.
Question 5
How to specify variables in the makefile?
Thank you!
One more question: Why are you using /stuff/sparkcore/firmware/main while the recommended folder is /stuff/sparkcore/firmware/modules?
Thank you!
For Question 5, see specific thread Local Build: How to Specify Variables in the Makefile?.
@BDub does the monolithic build work on the latest branch?
@BDub
No answer to my comprehensive post?
Thank you for bringing this issues. I tried all the failed test cases against release 0.4.6 (Oct 2 2015) and all the tests passed. Could it be you were using an older release?
The make target given is just program-dfu - which flashes latest built code to the device. To build the code first and flash it to the device you need all program-dfu as a target, as documented at device-os/docs/build.md at develop · particle-iot/device-os · GitHub
  • all: the default target - builds the artefact for the project
  • clean: deletes all artefacts so the next build runs from a clean state
  • all program-dfu: (not bootloader) - builds and flashes the executable to a device via dfu
  • all st-flash: flashes the executable to a device via the st-link st-flash utility
A clean build isn't necessary each time, only when switching branches.
Q2
I don't see these messages. What make command do you run that produces this?
Q3
COMPILE_LTO is an internal flag that the build system sets itself for different platforms. You do not need to provide this flag.
Test 2b, same cause as 1b - missing all target. :wink:
Test 2c, Q4 - this issue has been resolved in the meantime.
Test 3, Q5: This worked for me, in a test application I had
#if MY_IDE!=310
#error variable not defined as 310
#endif
I got the test to fail by excluding the user makefile (since the variable wasn't defined) and the tests passed when the makefile was used.
Please retry these tests with the latest branch or develop. They should work for you, but if not we can investigate further.
Thank you for your answer.
Unfortunately, the initial tests were performed and reported three months ago, in Oct '15, so I’m not sure I’ve kept the protocol.
In the meantime, almost everything has changed: new release of Mac OS X, new release of Xcode and thus make and obviously new release of the tools for Core and Photon local build.
I’ve found another solution with the MediaTek LinkIt One, which brings WiFi, Bluetooth + BLE, GSM + GPRS, GPS in one single board, plus full Wiring / Arduino implementation and compatibility.
Sorry.
The RedBear Duo board leverages Particle for the IoT infrastructure, and manages to compile with Arduino. Incidentally, this makes the board supported by embedXcode.
When does Particle plan to release the same feature for the Core and Photon?
Any update on this major feature?
Github All Releases Slack Status Donate Bitcoin GitHub issues GitHub stars Build Status Circle CI
Hi. @sej7278
I have recently been developing a script for installing and using the Particle Toolchain on Ubuntu-based Distros and OSX. I have done lots of testing and it is now very stable. Read more at po-util.com, or download it instantly with:
curl -fsSL bit.ly/po-util13 | bash
I had the opportunity to test the offline Particle Workbench for this Remote e-Paper Messages Panel project and I really liked it. It leverages the features of Visual Studio Code and offers cloud and local build. This is what I had in mind for an offline IDE many years ago…
