Posting for posterity because I didn’t find anything in a search:
If you’re running particle workbench, you might see this error with a local build:
stat: invalid option -- '%' Try 'stat --help' for more information.
The reason is make is executing the following:
head -c $((stat -f%z …/…/…/build/target/system-part1/platform-8-m/system-part1.bin.pre_crc - 38)) ../../../build/target/system-part1/platform-8-m/system-part1.bin.pre_crc > ../../../build/target/system-part1/platform-8-m/system-part1.bin.no_crc
The reason it is executing stat -f%z is because of the module.mk directive that sets it looks for windows and linux, then assumes vanilla bsd/osx without GNU tools /homebrew installed.
This command does work with /usr/sbin/stat on osx machines. But if you’ve got homebrew with coreutils, your stat may be the GNU version in /opt/homebrew/opt/coreutils/libexec/gnubin/stat
The fix is either to expand the full path of stat like so:
filesize=/usr/sbin/stat -f%z $1`
Or you can simply remove that entire ifeq block so filesize always = stat -c %s $1
I imagine this would also cause problems building on Cygwin for the same reason. One could do something like:
strings which stat | grep gnu and if that exits 0, assume gnu stat regardless of OS since that’s what really matters.
Hope this helps someone. (Probably me, later.)
