Linking problems with template class
Hopefully someone who’s better at C++ than me can help me figure this out.
I’ve found something pretty confusing. Today I wanted to experiment with implementing template classes on Particle. I keep running into a linking error if I include Particle.h. If I don’t include Particle.h it links fine.
I’m building for the photon on 1.4.0 in Workbench.
../../../build/target/user/platform-6-m/template-test//libuser.a(template-test.o): In function `setup':
/Users/nrobinson/projects/template-test//src/template-test.cpp:13: undefined reference to `Stack<int>::Stack(int)'
make[2]: *** [/Users/nrobinson/projects/template-test/target/1.4.0/photon/template-test.elf] Error 1
make[1]: *** [modules/photon/user-part] Error 2
make: *** [compile-user] Error 2
The terminal process terminated with exit code: 2
template-test.cpp
// Linking will fail if Particle.h is included
// #include "Particle.h"
#include "Stack.h"
// The following also fails to link
// Stack<double> doubleStack(100);
Stack<int> *intStack;
  intStack = new Stack<int>(100);
Stack.h
// Adapted from:
// http://users.cis.fiu.edu/~weiss/Deltoid/vcstl/templates
#ifndef STACK_H
#define STACK_H
template <class T>
class Stack
public:
	Stack(int = 10) ;
	~Stack() { delete [] stackPtr ; }
	int push(const T&);
	int pop(T&) ;  // pop an element off the stack
	int isEmpty()const { return top == -1 ; }
	int isFull() const { return top == size - 1 ; }
private:
	int size ;  // Number of elements on Stack
	int top ;
	T* stackPtr ;
#endif // STACK_H
Stack.cpp
#include "Stack.h"
//constructor with the default size 10
template <class T>
Stack<T>::Stack(int s)
	size = s > 0 && s < 1000 ? s : 10 ;
	top = -1 ;  // initialize stack
	stackPtr = new T[size] ;
 // push an element onto the Stack
template <class T>
int Stack<T>::push(const T& item)
	if (!isFull())
		stackPtr[++top] = item ;
		return 1 ;  // push successful
	return 0 ;  // push unsuccessful
// pop an element off the Stack
template <class T>
int Stack<T>::pop(T& popValue)
	if (!isEmpty())
		popValue = stackPtr[top--] ;
		return 1 ;  // pop successful
	return 0 ;  // pop unsuccessful
Put your implementation of the templated functions into the header file and see whether this works
The answer to this question provides the rationale behand that
That fixed all the problems. Thanks.
