Hey guys, this might be a little bit out of your knowledge, but I accidentally ordered a 24 RGBW LED without integrated drivers. The LED ring I was using before was 24 RGB LED with drivers. Does anyone know what I need to do or program to make the RGBW without driver ring work?
What are you hoping your LED ring will be able to do?
You mentioned your first ring had intergrated drivers, which suggests that you can control each led on the ring individually, or what had generaly become know as ‘neopixels’.
Your description of without intergrated drivers suggest as Moors reasonably assumed were tri/quad colour leds, mounted as a ring, which means you can only adjust the colours and brightness of the whole ring at a time. But lifes rarely that straight forward. Can you forward links of the leds ring you did use, and the link of the led ring you now have…
But as a whole the adafruit website has lots and lots of stuff on working with loads of different led combinations and well worth looking through… I even go back and referance it even now, just to make sure I don’t mess up ideas I’m playing with but might have done variations on a dozen times.
Wait… I almost didn’t catch the difference in the 2 product links you posted. Both are neopixel rings… which means they both have integrated drivers. The difference is that the first ring only has RGB pixels but the second link has RGBW pixels. The “W” means it has an additional LED on the die that outputs a white color (instead of using RGB color mixing to approximate white.) Take a look at this snippet from the Adafruit NeoPixel Uber Guide:
