It was undefined...
But your pull request looks like it should define it when RELEASE_BUILD is defined so that's good ![]()
Can you #define DEBUG_BUILD in the web IDE if you desire debugging?
It was undefined...
I will start a new topic. We absolutely need the PROGMEM functionality that arduino has which allows const vars to be read directly out of flash and NOT copied to RAM.
EDIT: https://community.spark.io/t/progmem-major-feature-requirement/3284
Hi @satishgn and @zachary and @david_s5 everybody
I have been doing a bit of research tonight with a local build of an empty application.cpp. I have been looking through the output from:
arm-none-eabi-readelf -a core-firmware.bin
I pulled the OBJECT lines and their sizes out into a spreadsheet and sorted them by size. Some of these are obvious like wlan_tx_buffer and wlan_rx_buffer. It looks like there are two 4k buffers that seem to be crypto related, RT0âŚ3 and FT0âŚ3. I looked at spark_protocol and there are some 294- and 612-byte keys plus a 640-byte queue, but that is surprisingly the largest single object. There are lots of good features in here like the USART_Rx_Buffer, but maybe that size could be optimized.
Here are the top memory hogs:
2064 spark_protocol
1064 impure_data
1032 __malloc_av_
1024 RT3
1024 RT0
1024 RT1
1024 RT2
1024 FT0
1024 FT3
1024 FT1
1024 FT2
1024 wlan_tx_buffer
1024 wlan_rx_buffer
352 User_Func_Lookup_Table
256 FSb
256 RSb
256 sbox
256 USART_Rx_Buffer
256 rsbox
200 __mprec_tens
200 User_Var_Lookup_Table
192 aes_test_cfb128_ct
176 expandedKey
140 sha1_hmac_test_sum
96 flash_codes
96 aes_test_cfb128_key
72 rx_buffer
72 tx_buffer
68 tSLInformation
67 profileArray
67 Virtual_Com_Port_ConfigDe
64 _ZL13exti_channels
64 aes_test_cfb128_pt
64 sha1_padding
64 USB_Rx_Buffer
60 sha1_test_sum
58 ip_config
56 lconv
50 Virtual_Com_Port_StringPr
48 aes_test_ecb_dec
48 aes_test_ecb_enc
48 aes_test_cbc_dec
48 aes_test_cbc_enc
48 Device_Property
40 RCON
40 _ZTV9USBSerial
40 __mprec_bigtens
40 _ZTV7TwoWire
40 __malloc_current_mallinfo
40 _ZTV11USARTSerial
40 ADC_DualConvertedValues
38 Virtual_Com_Port_StringVe
36 User_Standard_Requests
<stuff 32-bytes and smaller>
I am not sure where to go next . This is good data to understand where that base of around 11k is coming from, but is is not obvious what might need to be worked on from this list and what is already optimized.
OK, so I also should be looking at the addresses to see what is const in FLASH and not in RAM. The sbox and rsbox which are used by CC3000 security.cpp are in flash, for instance because the address 0x08015âŚ
1588: 08015e80 256 OBJECT GLOBAL DEFAULT 2 sbox
I do think there are two complete AES implementations in there right now, one in the CC3000 code and one in the tropicssl code.
There is a .map file in the build directory of core-firmware that has all the output generated by the linker which may be helpful for your research.
If you do
arm-none-eabi-nm -S --size-sort core-firmware.elf
youâll get a size sorted list of all the symbols. Along with each symbol is a single letter indicating âtypeâ, where T/t => text (not taking up SRAM), B/b => bss, and D/d => data.
nm docs:
https://sourceware.org/binutils/docs-2.21/binutils/nm.html
Youâll see spark_protocol as the biggest SRAM taker with 0x810 in the build I just did. Those FT0, RT0, etc are all const, so they donât use SRAM. These four are bigâthe CC3000 buffers and the other two I donât recognize:
20001f9c 00000400 B wlan_rx_buffer
20001b9c 00000400 B wlan_tx_buffer
20000704 00000408 D __malloc_av_
200002d8 00000428 d impure_data
Oh, thanks - played a bit more with nm:
arm-none-eabi-nm -S --size-sort -r core-firmware.elf --radix decimal --debug-syms --special-syms --synthetic | grep -e " [BbDd] "
gives a list with all RAM blocks, along with their decimal size, largest block first
However, the total of these amounts to 8k only, 7k of them for the largest 9 blocks.
Whereâs the 6k difference to the 14k gcc reports for bss+data coming from?
536874336 00002064 B spark_protocol
536871296 00001064 d impure_data
536872364 00001032 D _malloc_av
536877640 00001024 B wlan_tx_buffer
536878664 00001024 B wlan_rx_buffer
536873776 00000352 B User_Func_Lookup_Table
536873500 00000256 B USART_Rx_Buffer
536874132 00000200 B User_Var_Lookup_Table
536877288 00000176 B expandedKey
Zachary, those four items you listed add up to 4KB, leaving that 16KB âwallâ we are seeing in RAM. What are the qualifiers âBâ, âDâ and âdâ?
Thanks! That makes is much easier to understand. Reading online a bit, these:
are coming from newlib. These can be controlled with switches (or other implementations of new). impure_data is used to allow functions to be reentrant and some space is always needed.
I think from the top few it is clear that the great new stability and other features like interrupt-driven USART come with a RAM price tag. Maybe some of the advanced folks here can experiment with reducing sizes and see if the price can come down at all.
I think david_s5 pegged it when he said that the Spark needs a proper dynamic memory manager. The Spark Team is aware of this and if david_s5 has the time, we will see something in a future sprint.
So if I understand correctly, there is about 6KB of RAM left for user apps. If a user creates a TCPClient or UDPClient, these eat up 512B of RAM in buffers (?) each. It is not clear to me that const vars are not being copied out to RAM so that 6KB can disappear really fast!
@bko @peekay123 @zachary @luz Good work pulling this together! All good points. I think there should be a branch created with an eye on transforming the code into a more âoptimized for a resource limited embedded systemâ
After 20+ years of embedded development, I have leaned that it is better to over optimize everything: power management, speed, ram, flash constantly. This can be hard to do, with a deadline driven project or deadline driven feature requirement and varying skill sets. But if every line of code, module designed, feature added is optimized from the âget goâ the âworld is a better placeâ
Having said that, most of the projects I have gotten involved with, have resource issues. One project, had an insane âout of runwayâ deadline of 3 months to production. So I specked the fastest, biggest RAM, FLASH MPU I could find that would meet the run on battery for X hours requirement. But still every line of code, module designed, feature added was optimized.
There are 3 way that come to mind to mitigate embedded resource constraint:
Given the degrees of freedom: time, skills, money
design spiral proto, test , learn, optimize, fix, on feature branches. integrate repeat while converging on goal.
or as I like to think of it as
design spiral costs time to revisit, requires skills to get the the goal,
N tiers of development team: tier 1 does quick feature BRANCH, (may have to #ifdef out stuff to get it to fit), tier 2 does optimization and integration to master. Skill sets increase as N goes up.
Faster time to goal,costs money, requires teams with increasing skill sets.
Optimizations :
The byte killer branch: The ARM support Bit-banding - right there all the bools,uint8_t
The misuse branch: kill things like uint32 for things that have 0:1, 0:-255 range
The power branch: Use interrupts remove all poling optimize IPC and queues
The Clever reuse branch: eliminate copies and use ti buffers in a clever way
The Heap branch: put in a real heap management.
The tricks of the trade branch: Use trick of the trade: For example a buffer is by definition empty or full. Therefore one does not need buffer, on, off. Just buffer and offset, or better yet store the data backwards offset will equal count and the next pointer. cool huh!
So how should we do this?
@david_s5 You are a great asset to this community!
david_s5, I believe targeted optimization may be the way to go. Itâs clear that the immediate need is for better RAM resource management especially in the numerous buffers and heaps and whathaveyounots. The design spiral is great but letâs face it - if the STM32 had more flash and RAM, we would worrying about other things instead of these resources. Perhaps the spiral with clear resource optimization goals is another way to go, not unlike what is happening with the WAN/CLOUD connect/disconnect evolution.
Less than a handful of folks (including you of course) are truly capable of optimizing this puppy. So which way do you think we should go?
Hmm, at the moment I think it would always be âRELEASE_BUILDâ, since weâre not setting the DEBUG_BUILD environment var before builds. I think we could add an option to pass in a set of build flags, I suspect the tricky part becomes presenting those options in a clear way.
# https://github.com/spark/core-firmware/blob/compile-server2/build/makefile#L82
ifeq ("$(DEBUG_BUILD)","y")
CFLAGS += -DDEBUG_BUILD
else
CFLAGS += -DRELEASE_BUILD
endif
