JSON template for Open Weathermap webhook
Apologies if this has been covered elsewhere, I’m struggling with setting up a response template in webhooks.
I’m polling the open weathermap API with a webhook and I’m receiving a response, the following works:
void myHandler(const char *event, const char *data)
if (data)
// do the thing
But I only want to use a small part of the JSON response so I added a response template to the webhook. The JSON specifiction for open weathermap is here:
http://openweathermap.org/current#current_JSON
And my response template in webhooks looks like this:
{{weather.main}}
The code below isn’t working.
if (data == "the current value")
// do the thing
Obviously data being returned isn’t matching the condition in the if statement but I can’t see why.
Two questions, hoping you guys can help:
Does the response template I’ve written look right?
How can I view the value of the “data” variable?
Many thanks
With char* you can't just use the == operator, you need a function like strcmp() to test for equality.
The equality operator (==) would only compare the values of the two character pointers and not the contents of the respective memory locations.
e.g via Serial.println(data)
Many thanks, I'll have a look at strcmp()
I'm probably being really dumb, but how do I use Serial.printIn ? Do I view the output in CLI?
You can view the output via CLI
particle serial monitor --follow
But you could use any other serial terminal program on your computer.
I figured out the JSON response template, webhooks uses the Mustache syntax, {{weather.0.main}} did the job
