If I hard coded:
args="{“d”:[0,1,0,1,1,1,1],“p”:[0,1,100,120,12,00,11,30]}" everything works but when I send the string with a particle functions call the same string:
parseObject() failed error.
Do I need to send quotes and back slashes? I tried all possible combo but still failing.
int parseJSON(String args){
Serial.println("length: ");
Serial.println(strlen(args));
char json[strlen(args)];
strcpy(json,args);
Serial.println(json);
StaticJsonBuffer<2000> jsonBuffer;
//char json[] = “{“name”:“gps”,“time”:1351824120,“data”:[1,1,1.00,55,0],“data2”:[1,1,1.00,55,0]}”;
JsonObject& root = jsonBuffer.parseObject(json);
if (!root.success()) {
Serial.println(“parseObject() failed”);
return -1;
//return -1;
…continues
