Is there an alternate OS for the original Photon with no cloud needed?
Hi everyone,
Just chasing down a rumor that maybe there is a way to use the dozens of old photons I have without needing any cloud connectivity. Is that true? Does such a solution exist?
Thanks for any tips or leads.
-B
The Photon 1 still has cloud support and can be programmed by all current environments (Workbench, CLI, Web IDE).
However you can also program the Photon 1 by USB and use
SYSTEM_MODE(MANUAL);
which will cause the device to breathe white instead of cyan and operate with no connectivity.
You are saying I can program and use a photon 1 without ever touching the cloud?
Yes. Use Particle Workbench with the local compile and flash by USB option, and use the line I included above in your firmware so it won't attempt cloud connectivity.
If you want Wi-Fi but not cloud, use:
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
In setup(), do
WiFi.connect();
You can then use TCPClient, TCPServer, and UDP without any cloud access. Note that the real-time clock will never be set in this mode.
Thank you!
