I want to connect two devices to photon particle and both of the device needs Rx and Tx pins and works at the baud rate of 9600, is their any way to connect both of them on a single photon particle ? Thanks in advance
If you search the forum for that term you might find an answer.
For what term, like I have searched for similar things but didn’t find any satisfactory answer for it. Thanks
Try this library
I’ll definitely give a shot to this and revert back things. Thanks
SoftwareSerial would be the most obvious search term I'd guess.
It even appears in your topic title and probably would in other threads that had raised that question before you ![]()
