I’m sure that the iOS developers are working on this already but if anyone has run into an issue I found that removing the NS
prefix from all declarations (or wherever it throws you an error) and changing AnyObject
to Any
also fixes the issue. So far I only tested it on login
and getDevices
but it does work!
Yea, I already committed this change to the library but have not yet published a new pod with an example - but basically this is the only change required for Swift 3.0 compatibility
