I’ve got a current IOS app working that gets data from a photon particle variable when I press a button on the IOS screen. I’m using Xcode 9.2, IOS 11.2, iPhone X, CocoaPods.
I want to morph the code so that the app subscribes to an event, then displays this data and updates it as a new event is published.
Are there any working examples of a similar IOS app that I can play with?
I’m pretty green with my Xcode programming, so even though I see the subscribe code in the SDK docs, I’ve been unable to get it to work.
What code did you try to get the subscription to work, and what result did that code give you? Also, are you using the latest SDK, where it uses Particle instead of Spark?
Well, the code is Objective-C, my swift is pretty lacking.
I’ve simplified my code as much as I can to focus on just getting the subscription.
So first - I’m not sure where to put the event listener, I put it in
viewDidLoad()
after my login (which might not be right, especially as it is in a void declaration), in the viewcontroller.m file, and I put the handler later in the same file.
Currently I get this warning at the line where I subscribe:
I don’t know how to deal with the variable to get it into a label, which is called Total Time.
I left in the IBOutlet line that I used to put a particle variable totalTime into the label, and know that will have to be modified, but I’m not sure how to do that, either. I fear that my skills are so basic that you guys will just tell me to go back to school!
Viewcontroller.m code:
#import "ViewController.h"
#import "Particle-SDK.h"
@interface ViewController ()
@property (weak, nonatomic) IBOutlet UILabel *totalTime;
@end
@implementation ViewController
- (void)viewDidLoad {
[super viewDidLoad];
// Do any additional setup after loading the view, typically from a nib.
[[ParticleCloud sharedInstance]
loginWithUser:@"******@****.com"
password:@"*******" completion:^(NSError *error) {
if (!error)
NSLog(@"Logged in to cloud");
else
NSLog(@"Wrong credentials or no internet connectivity, please try again");
id eventListenerID = [[ParticleCloud sharedInstance] subscribeToDeviceEventsWithPrefix:@"time" deviceID:@"******************" handler:handler];
ParticleEventHandler handler = ^(ParticleEvent *event, NSError *error) {
if (!error)
dispatch_async(dispatch_get_main_queue(), ^{
NSLog(@"Got Event %@ with data: %@",event.event,event.data);
else
NSLog(@"Error occured: %@",error.localizedDescription);
- (void)didReceiveMemoryWarning {
[super didReceiveMemoryWarning];
// Dispose of any resources that can be recreated.
@end
I wouldn’t worry about that warning for now (the eventListenerID is used for unsubscribing). It should be ok to have the subscribe line in viewDidLoad. Is your login working or not (which log gets printed out)? How are your publishing? Is the publish statement marked with PRIVATE? It need to be for subscribeToMyDevicesEventsWithPrefix, and I think it should be for subscribeToDeviceEventsWithPrefix:deviceID: too.
Finally, what result does this code give you? Just nothing, or is it crashing or not compiling?
The login works. It does compile. The publish is marked private, I’m just using a fixed value in it to begin with as below:
Particle.publish(“Speed”, 27, PRIVATE);
It logs in and I get the message Logged in to Cloud, but I never see anything in the log to show that the Event was received or that an error occurred. Maybe I should try it without the DeviceID?
You do need a property (or variable) for that label somewhere. It can be in the .h or .m file. Do you have one, and is it connected to a label in the storyboard? It’s strange that the error you’re getting is about “self” though.
It’s not clear to me why it’s not working then. Sometimes the error messages aren’t identifying the correct problem. Please post the entire method that this line of code is in. I have to say I’m a little rusty on Objective-C these days. I moved on to Swift 3 or 4 years ago.
As I said, I’m pretty rusty at Objective-C. Try this instead and see if it works,
loginWithUser:@"****@***.com"
password:@"*********" completion:^(NSError *error) {
if (!error)
else
id eventListenerID = [[ParticleCloud sharedInstance] subscribeToDeviceEventsWithPrefix:@"Speed" deviceID:@"**********" handler: ^(ParticleEvent *event, NSError *error) {
if (!error)
self.totalTime.text = event.data;
else
