Como puedo convertir el resultado de este codigo a integer
#include "Adafruit_DHT_Particle.h"
#define DHTPIN TX
#define DHTTYPE DHT11
String sendData;
DHT dht(DHTPIN, DHTTYPE);
dht.begin();
delay(10000);
float temperatura = dht.getTempCelcius();
sendData = String::format("%4.2f C", temperatura);
Particle.publish("Temp", sendData);
int x = temperatura; // truncate result
int y = temperatura + 0.5; // "round" to next integer
thanks so much, but you refer a this example:
#define DHTPIN TX
String sendData;
dht.begin();
delay(10000);
Particle.publish("Temp %d", y);
// I keep getting the same error
// dht-test.ino:30:31: invalid conversion from 'int' to 'const char*' [-fpermissive]
If I translated this correctly, your question was how to convert the result to int but what you now appear to actually be looking for is how to convert an integer to const char* or string.
If the question were asked that way this would have been the answer
sendData = String::format("%d C", y);
Particle.publish("Temp", sendData, PRIVATE);
However, then I wonder why you want to do that at all.
If you stick with float but don’t want any decimal places you’d just do this
// since I prefer char[] over String
char sendData[16];
snprintf(sendData, sizeof(sendData), "%4.0f C", temperatura);
sendData = String::format("%4.0f C", temperatura);
