Tahl
1
I can’t seem to get it to work…
I do the macro to enable the feature:
STARTUP(System.enableFeature(FEATURE_RETAINED_MEMORY));
Then declare the variable such as:
retained String status1 = “00000|0|–|”;
Then somewhere along the way, I do a System.reset(); It should retain the changed value of status1, no?
Thanks for any insight…
Tahl
How are you determining if the value is retained?
Tahl
3
@kennethlimcp Sorry, put doing a published variable.
I cannot remember if string is supported.
You can using a char array and see if that works.
https://docs.particle.io/reference/firmware/electron/#storing-data-in-backup-ram-sram-
AFAIK String isn’t supported since the actual content of the object lives on the heap and not in the Backup SRAM area.
char[] is the way to go with that.
