Is there a way to install the latest version or atom and particle dev from terminal?
It seems GitHub is a little to confusing for me. I’m welcome to other instructions on how to install from git hub.
I have deleted atom from my computer and want to start fresh with the latest version of Atom and particle dev. I tried entering the following commands in terminal
git clone https://github.com/atom/atom.git
cd atom
script/build
and when the long process ends it yeilds:
Skipping code-signing. Specify the --code-sign option to perform code-signing
Skipping creating installer. Specify the --create-windows-installer option to create Squirrel-based Windows installer.
Skipping creating debian package. Specify the --create-debian-package option to create it.
Skipping creating rpm package. Specify the --create-rpm-package option to create it.
Skipping artifacts compression. Specify the --compress-artifacts option to compress Atom binaries (and symbols on macOS)
Skipping installation. Specify the --install option to install Atom
I was prompted to update after getting a error when trying to compile. The error was in node.js and the program suggested i update atom/ particle dev
