Initialising arrays in class constructor
Hi everyone,
A newbie question. I have created a class (simplified version), with the .h as below:
class LimitlessLED {
  public:
    LimitlessLED();
    void sendUDP(byte *cmd);
    void setBrightness(int level);
    void setColour(int col);
    void setBrightness(int gp, int level);
    void setColour(int gp, int clr);
    int control(String cmd);
  private:
      byte white_ALL_off[2];
With the constructor in .cpp:
LimitlessLED::LimitlessLED() {
  this->white_ALL_off  = {0x39,0x00};
I get compilation error with error: assigning to an array from an initializer list
What is the problem with initialising default array variables in a constructor?
Thank you for your guidance! :smile:
Regards,
Tim
Great question Tim! If you know the initial values of the array at compile time:
  • You should declare them once static for the class instead of once for every copy of the object.
  • You should put it in flash with const to save on precious SRAM.
  • You can just directly define the array values before object construction.
Example:
  private:
    static const byte white_ALL_off[2];
const byte LimitlessLED::white_ALL_off[] = { 0x39, 0x00 };
Hope that helps! If not, don’t hesitate to ask more questions.
Cheers!
Thank you for taking your time to answer my question, @zachary! :smile:
