does someone have an idea why my display looks all screwed up?
It’s all fine and dandy at first:
But after a few minutes the colours go funny and the text goes all over the place.
Have you seen something like this?
@volker, you could be sending data too fast for the display so check your SPI settings. How long are the wires between the Particle device and the display? Are you using a specific library to drive the display?
The cables are 8 inch / 20cm.
I have followed your advice and checked the cable connections.
I disconnected everything and re-connected.
Now the problem disappeared. It seems that there were connection issues. Thanks,
