I am working with the Electron at firmware 0.6.0. When I use 2 I2c ports (wire and wire1), I see at wire1 the same response as with wire (but all the chips were connected to wire).
Is this bug solved in the higher firmware version (0.6.2) ?
We currently have some fixes in the works for bugs we’ve observed with wire1. They are based on this GitHub issue. If that’s not quite what you are observing, you can contribute or log your own GitHub issue for the bug you’ve found so we can keep track of these problems. As of right now though I know wire1 is not behaving as expected and it is a work in progress.
