I am developing a product based on Boron LTE that uses an OLED display. I have tried two different displays (SSD1306 OLED 128x64 using I2C, and SH1106 OLED 128x64 using SPI). I’m using the SSD1306 and SH1106 libraries from Adafruit in my tests. I have not yet been able to get u8g2 to work without crashing, so I haven’t tested that yet.
Both displays show the same problem. After a while (minutes, or maybe hours) the display flips vertically, thus showing an upside down image. From time to time after that flip it also corrrupts occasionally, with graphics skewed left to right, or completely garbled. It recovers from that corruption on the next refresh, but still the display is upside down. It only goes back to normal orientation after a reset.
Currently I’m using the SH1106 SPI 128x64 display for testing. Has anyone else seen this problem? I haven’t been able to find it in my searches of this board.
EDIT: I had 4.7K pullup resistors on the I2C signal and clock lines. I have no pullups on SPI.
EDIT 2: Display is flipped vertically, and the horizontal skew does not appear to correct itself until reset.
