I want to use a static IP, but there is a problem with DHCP mode operation
const uint8_t IP_ADDRESS_ARRAY = {192, 168, 35, 222};
const uint8_t NETMASK_ARRAY = {255, 255, 255, 0};
const uint8_t GATEWAY_ADDRESS_ARRAY = {192, 168, 35, 1};
const uint8_t DNS1_ADDRESS_ARRAY = {210, 220, 163, 82}; // 1차 DNS
const uint8_t DNS2_ADDRESS_ARRAY = {168, 126, 63, 1}; // 2차 DNS
SYSTEM_MODE(MANUAL); // OS 제어권 확보 (필수)
// 1. 초기화 및 자격 증명 설정
WiFi.disconnect();
WiFi.clearCredentials();
WiFi.setCredentials(ssid, pass);
// 2. 고정 IP 강제 설정 (connect() 직전)
WiFi.setConfig(NetworkInterfaceConfig()
    .source(NetworkInterfaceConfigSource::STATIC)
    .address(IP_ADDRESS_ARRAY, NETMASK_ARRAY)
    .gateway(SockAddr(GATEWAY_ADDRESS_ARRAY))
    .dns(SockAddr(DNS1_ADDRESS_ARRAY))
    .dns(SockAddr(DNS2_ADDRESS_ARRAY)));
// 3. 연결 시작
Serial.println("Attempting Static IP connection...");
WiFi.connect();
// 4. 연결 후 IP 확인 (고정 IP가 나와야 함)
if (waitFor(WiFi.ready, 20000)) {
    Serial.print("Final IP: ");
    Serial.println(WiFi.localIP());
} else {
    Serial.println("Connection failed.");
I want to use a static IP, but I'm having trouble with DHCP mode.
I flashed the above code to my Photon2, and it's running in DHCP mode.
(I also flashed it in DFU mode, and it still runs in DHCP.)
How can I assign a static IP?
Thank you for your help.
The problem is that you need to specify the profile name, which is your SSID, in the configuration or it won't take effect.
    .profile(SSID_NAME)
