I’m doing it wrong somewhere but I do not understand. I ask for your help.
From time to time (sometimes 20 minutes, sometimes 3 hours, etc.) when I write the code as below, the wifi connection is disconnected and reconnected. But this is a big problem for me because blynk always gives a warning.
void loop(void) {
Particle.process();
Blynk.run();
if (!Particle.connected())
//// if particle not connected else restart wifi and restrat photon
if((millis()-sistem_last) > sistem_bekle){
con_test_count--;
if(con_test_count > 0){
WiFi.off();
WiFi.on();
sistem_last = millis();
String mesaj = Time.format(Time.now(), "%H:%M") + " - Wifi Yeniden Başlatıldı";
terminal.println(F(mesaj));
terminal.flush();
else
System.reset();
else
if((millis()-blink_last) > blink_bekle){
TX_LED.on();
if(status){
TX_LED.setColor(BLYNK_RED);
else
TX_LED.setColor(BLYNK_GREEN);
status=!status;
// BATTERY FAILURE /////////////////
if((AKU_DEGERI<23 || AKU_DEGERI>29))
AKU_HATA = true;
else
AKU_HATA = false;
if((AKU_DEGERI>23 && AKU_DEGERI<29))
AKU_NORMAL = true;
if(AKU_HATA == true && AKU_NORMAL == true){
String mesaj = Time.format(Time.now(), "%H:%M") + " - " + "SERVICE BATTERY FAULT";
Blynk.virtualWrite(V7," System Fault ");
Particle.publish("pushbullet", mesaj, 60, PRIVATE);
Blynk.notify(mesaj);
terminal.flush();
AKU_HATA = false;
AKU_NORMAL = false;
// 74165 ERROR SENDING /////////////////
// pinValues1 AND pinValues2 values read in Timer action
if(pinValues1 != oldPinValues1) //74165 değerlerini eski değerle karşılaştır
String mesaj = "";
//74165(1)
Blynk.setProperty(V7, "color", BLYNK_RED);
for(int i = 0; i < DATA_WIDTH; i++)
switch (i)
case 0:
if(!((pinValues1 >> i) & 1)){
STARBOARD_RUN = TRUE;
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "STARBOARD GEN RUN";
//Blynk.virtualWrite(V7," System Fault ");
else
STARBOARD_RUN = FALSE;
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "STARBOARD GEN STOP";
break;
case 1:
PORT_RUN = TRUE;
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "PORT GEN RUN";
else
PORT_RUN = FALSE;
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "PORT GEN STOP";
break;
case 2:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "STARBOARD GEN FAULT";
break;
case 3:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "PORT GEN FAULT";
break;
case 4:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "SEWAGE TANK FAULT";
break;
case 5:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "NO SHORE AC";
else
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "SHORE AC OK";
break;
case 6:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "PORT ENGINE BATTERY FAULT";
break;
case 7:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "STARBOARD ENGINE BATTERY FAULT";
break;
case 15:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "ENGINE ROOM INTERFACE FAILURE";
break;
terminal.flush();
mesaj = "";
oldPinValues1 = pinValues1;
if(pinValues1 == 65535 && pinValues2 == 65535){
Blynk.virtualWrite(V7," System NORMAL ");
Blynk.setProperty(V7, "color", BLYNK_GREEN);
if(pinValues2 != oldPinValues2) //74165 değerlerini eski değerle karşılaştır
String mesaj = "";
//74165(2)
switch (i)
case 0:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "BILGE 5 WATER ALARM";
break;
case 1:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "BILGE 4 WATER ALARM";
break;
case 2:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "BILGE 3 WATER ALARM";
break;
case 3:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "BILGE 2 WATER ALARM";
break;
case 4:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "BILGE 1 WATER ALARM";
break;
case 5:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "FIRE ALARM";
break;
case 6:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "RADIO BATTERY FAULT";
break;
case 7:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "EMERGENCY BATTERY FAULT";
break;
case 8:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "D6";
break;
case 9:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "D7";
break;
case 15:
mesaj = Time.format(Time.now(), "%H:%M") + " - " + "BRIDGE INTERFACE FAILURE";
break;
terminal.flush();
mesaj = "";
oldPinValues2 = pinValues2;
//delay(POLL_DELAY_MSEC); zaten 500ms tekrar ediyor
if(millis() > 864000000) //10 day after restart photon
System.reset();
blink_last = millis();
con_test_count = 3;
if(!wifidurum){
wifidurum = true;
String mesaj = Time.format(Time.now(), "%H:%M") + " - " + "Wifi yeniden bağlandı";
terminal.flush();
dongu2 = millis()-dongu;
dongu = millis();
