I can trigger a particle function but it never receives my argument
Please let this be one of those times where I am missing something obvious. First things first, here’s my code:
Node:
var Particle = require('particle-api-js');
var particle = new Particle();
var token = '###abc'; //verified
var deviceId = '###'; //verified
var fnPr = particle.callFunction({ deviceId: deviceId, name: 'myfunction', argument: 'myData', auth: token });
fnPr.then(
    function(data) {
        console.log('Function called succesfully:', data);
    }, function(err) {
        console.log('An error occurred:', err);
Particle:
    Particle.function("myfunction",myFunction);
void loop() {}
int myFunction(String command) {
    if (command == NULL) {
        return 1;
When running the node script, I get the following back:
Function called succesfully: { body:
    { id: '##########',
        last_app: '',
        connected: true,
        return_value: 1 },
    statusCode: 200 }
Just to make sure I wasn’t crazy I also flashed my particle with this:
void loop() {}
    return 123;
And sure enough, got this back:
     { id: '###########',
         last_app: '',
         connected: true,
         return_value: 123 },
     statusCode: 200 }
Any idea on what in the heck is going on?
@dadschool
I wouldn’t recommend using NULL, as it is not possible for command to be NULL due to the int myFunction(String command) making myFunction require a String argument. Also Particle.function will pass an empty string to myFunction if “myfunction” is called with no arguments in JSON. Try something like if (command == "") to test if the string is empty. I would also recommend trying to debug over serial to be 100% sure it is working. Put Serial.begin(9600) in your setup, and Serial.println(command) in myFunction.
Your code works correctly for me when I call it from the CLI; I’m not able to reproduce your odd result. BTW, you really should have an “else” clause, so something is still returned from the function if the “if” isn’t executed.
@Ric
Great point. If a cloud function doesn't return anything it can get ugly.
Edit:
What worked? The first one or the second?
I doubt the first would work correctly.
The first one did work correctly. If I pass nothing, or an empty string, it returns 1, if I pass an argument, it returns 0 (or some other number if I put in an else clause).
Weird, I wonder why @dadschool is having problems then.
Unfortunately (command == “”) yields the same results :pensive: I am working to configure connection over serial.
Ric I didn’t include an “else” because I wanted to keep the code posted here pretty spartan.
Did you try calling the function from the CLI to see if you get the same results
Spartan is good for posting but the code should still be fully valid.
I might even suggest not necessarily to add an else branch, but make it a habit to have an unconditional return statement in each and every function that is supposed to return a value.
A possible useful statement for your problem might be this statement return command.length();, since it always has something to do with your input too.
And for your NULL, you might consider -1 as return value to distinguish between a one-char string and an empty one :wink:
And, as @Ric said, I'd guess your problem is in your calling code and not the firmware.
Adding Serial.println(command); in your function (or setting up a Particle.variable()) to see what data you actually get posted - as @nrobinson2000 suggested - is a good idea for debugging too.
@nrobinson2000, while it is true that the String parameter will never be NULL, there is an overload for the == operator that takes care of that. It will implicitly compare the internal C string against an empty string when you compare against NULL.
unsigned char operator == (const char *cstr) const {return equals(cstr);}
unsigned char String::equals(const char *cstr) const
	if (len == 0) return (cstr == NULL || *cstr == 0);
	if (cstr == NULL) return buffer[0] == 0;
	return strcmp(buffer, cstr) == 0;
Whoops, forgot to mention, when watching the console while submitting a function call via javascript, an empty line is added to the console, and the “test” command comes over fine.
EDIT: Forgotten important details
I just read today that another member had issues with particle-js-api 6.0.0.
Can you try the latest 5.x.x?
Haha, I was doing that right now. Yes, that solved it.
There was also issue with particle.login method earlier as well, but I had chalked it up to bad copy/paste at the time.
Well that was a fun couple hours. Thanks again everyone who answered late on a Saturday night!
This was the post I had earlier above, I removed it because my edit history contained some uncensored info. This would have been directly below ScruffR’s first comment.
Here is my current code
Particle
void loop() {}
    Serial.println("test");
    if (command == "") {
        return 1;
    } else {
        return 2;
Node
fnPr.then(
    function(data) {
}, function(err) {
CLI
particle call ############ myfunction "frustration"
Running CLI Returns:
2
Running via Javascript Returns:
    { id: '##########',
        last_app: '',
        connected: true,
        return_value: 1 },
    statusCode: 200 }
Extra Stuff
particle-js-api version: 6.0.0
There’s a version 6.0.1 released now that fixes the login issue and this issue as well. Sorry for causing some frustration on a Saturday :bow:
