Huge data consumption by electron even on standby mode
I am having my particle gather sensor data for about 7 seconds. Then after publishing the data to the cloud, I am putting the electron to stop mode standby sleep for ~10 minutes. When my electron wakes from stop mode standby it goes straight to breathing cyan. I thought this would save data because I don’t have to reconnect after waking up each time. Instead, here’s what I’ve observed:
  • In the first 40 minutes (5 publishes), my data consumption jumped from 4.69 to 4.75 MB. Isn’t that a bit high?
  • After each publish, my device also does a handshake (as seen on the console), aka every 10 minutes. Since in standby the particle should maintain a connection to cellular, why is it handshaking after every publish?
I am using the google maps device locator, which might be consuming a lot of data? But besides that I don’t know what else might be eating up my data…?
Code: https://go.particle.io/shared_apps/5c4ccec8405ba50386000419
You should insert this code at the top of your source file:
and monitor the USB serial debug output. Since you’re sleeping, you’ll probably want to use:
particle serial monitor --follow
so it will reconnect the USB serial port.
That will show whether it’s doing a full handshake, session resume, or just continuing on with no data usage.
