Good day community!
I have got some bad photons here: one has a dim blue light on the pin D7 and others are suffering hard faults. The programmer shield I ordered for has arrived but I am having difficulty installing the OpenOCD on windows. I read your Github repository @rickkas7 about JTAG. You did not clarify how to install the OpenOCD. A note on this will be greatly appreciated.
Even so, I will welcome a detailed way of restoring the photons using the PROGRAMMER SHIELD. Thanks.
The best way is to install Particle Workbench. It will install OpenOCD for you, and it’s way easier than installing OpenOCD manually.
Thank you greatly.
